No internet on wifi or data
- By MrJavi
- Smartphones
- 8 Replies
How exactly would I install this with no way to transfer data to or from phone?
Possible workaround. Seems bluetooth still works
installing to your new phone and sending the app to your old phone vis Bluetooth.
Well according to your on words "
Possible workaround. Seems bluetooth still works." and Bluetooth is a method of transferring data. You ask how, install the app I recommend on your new phone and use it to transfer the same app "Bluethooth Sender" to your old phone. The use bluethooth sender from your old phone to transfer data to your new phone.
Thats how you transfer data by means of bluethooth.
You could try booting into safe mode and check your wifi.
