ADB reverse and TCP communication
Hi
I have Android Studio 4.1, with ubuntu 18.04 in a VMWare Virtual Machine on a Windows 10 laptop. I have connected (using USB3) a Samsung Active 2 Tab up to the laptop (USB3) and Android Studio communicates with it. I can get an app to run on the device from Android Studio and with the help of ADB's command reverse, I can create a server in an Ubuntu terminal in the VM that the app on the device can then read from using Sockets.
First thing I do is:
Code:
mike@ubuntu:~$ adb reverse tcp:1234 tcp:1234
The client code on the device is simple:
Java:
Socket socket = new Socket(hostname, port);
InputStreamReader input = new InputStreamReader(ocket.getInputStream(), StandardCharsets.UTF_8);
BufferedReader br = new BufferedReader(input);
String msg = br.readLine();
Log.i("MESSAGE SAYS: ", msg);
input.close();
The server in the Ubuntu terminal is even simpler:
Code:
mike@ubuntu:~$ nc -l 1234
hello
logcat in Android Studio displays the response the client gets from the server:
Code:
MESSAGE SAYS: hello
So my question (whew, sorry about so much blabber above):, is this actually a TCP operation or is adb doing the actual bridging (listening and doing some sort of loopback) with the network traffic? In other words, can USB3 actually have a TCP connection?
Thanks...
Personal Ringtones on Nord
Hi
Just bought a Oneplus Nord, how can I upload my personal ringtones, they are present on the phone in Dropbox, but it can't see them to use.
I've plugged in to Windows via USB but only five files show
adb_config_Linux_0SX.sh
Androidfiletransfer(0SX).dmg
Autorun.inf
Oneplus_setup.exe
Oneplus_USB_drivers_setup.exe
None of which are any use to me.
My daughter has a different Oneplus and has no bother, she's looked at mine and it's different when plugged in.
So that's what the phone shows when you plug it into your PC? It looks like drivers for MacOS and Windows, that you might need to install to use with this phone when connecting by USB. If you're using Windows, try running the "USB_drivers_setup.exe" one.
If the files are in your Dropbox, think you need to download them first to the phone's local storage before they can be used as ringtones.
Feel Free to Delete- No longer Needed , Reset on Accident.
Sorry if I missed something, I only had time to skim these long walls of text...
In twrp have you gone to the "mount" menu then select "enable mtp"?
Apologies if that's not the exact wording but I haven't been in there in awhile and don't have twrp permanently installed to be able to check right now.
That's what I thought.
Paragraphs are your friend, that's what I tell my students. :thumbsupdroid:
Planning to Install Solar Panels
Actually, you may need to consult with solar providers, as the requirements might be very different for each site, its location as well as your needs. When I was about to install solar panels, I used to ask a lot of question like you to almost everyone with solar experience but it turned out that my case was a bit different and none of the suggestions was feasible for me. Then, I contacted directly to the company I wanted to go solar with and they helped me a lot to make an informed decision. BTW, they do operate in California. You may visit LA Solar Group on FB and PM them your number with consultation request. I'm more than sure they'll help you.
I'll definitely do, thanks. BTW my collogues recommended LA Solar services as well. Seems they really provide that quality.
Finder question, keyboard not showing up as default !?
Just swapped my Huawei Mae 20 Pro with S20 Plus.
When I open the Finder app the keyboard show up automatically and Im able to search without clicking the serarch field.
However, when I swipe down from homescreen it opens Finder, but then I need to click the search field for the keyboard to appear.
Why is that ? I want the keyboard to automatically show up.
Anyone know ?
Filter
