Got Android 11 Last Night
I wouldn't dare try defining the term if it were a serious discussion... it's obviously subjective depending on everyone's own opinions. .. For instance, I can make some complex spreadsheets, but I wouldn't call that programming excepts in the most basic sense at best. Still, I suspect if someone is creating a "toast message" to pop up information... I'd assume they are creating some type of app or program.
I could certainly venture a guess ( ie big grain of salt ) on why a toast message from an app/program that is in the background is no longer supported... would be to help save power. It seems that the newer Android OS versions allow fewer background apps running in the background without specific permissions for that purpose... it's make sense if they are doing similar things for toasts and notifications as well. Still, that is coming from a non-dev type and may have nothing to do with it.
Of course it seems at times that Google acquires, creates and then kills perfectly good stuff quite often .. often without saying why they did it. So at that point, it's probably anyone's guess.
Double apps
How would i know if a work profile is on here?can having 2 emails on one phone cause this?
Is the device new?
If so, you would need to activate the work profile yourself in order for it to be active.
A quick way to see is to look in your apps list and see if key apps are repeated- Google, Chrome, Play Store- that sort of thing.
If those apps are singular, you most likely don't have a work profile activated.
Another way to see is to pull down your quick settings menu, enter the edit mode, and look to see if the work profile quick setting icon is available.
It is a toolbox, or like an old time lunch box.
Graph data on Android
hi, everyone I have a question for you all, I have a graphic sample and I need to reproduce the same graphic, but I don't know how, my question which framework or library can I use in order to obtaint the result? for doing this I will attached the sample, if someone can help me out I really appreciate your support.
Filter
