Help Custom ROMs for Galaxy Tab 3 SM-T110
- By felixxx23
- Ask a question
- 3 Replies
hola amigo tengo ese mismo modelo de tab 3 lite sm-t110 tendras la rom q le pusiste????
Great! @Dannydet had the answer first, I just sorta fine-tuned it a bit LOLIts under warranty..
The userdata partition is encryptedso there is no easy way of recovering even if you retrieved the userdata image from it.
