New Game: Popup Invasion (Version 1.0.1)
- By App Update
- Apps & Games
- 0 Replies
EXTRA INFO
- Rating: 4.4
- Installs: 10+
- Download Size: 7.4M
- Version: 1.0.1
How do I crop the xbox video when it's me playing the game and streaming it to my phone??
Hi, Guys. Thanks for all the great info and suggestions. It's late here tonight, but I was successfully in enabling Developer Options on my LG Android phone. Within a few day, when I have the time, I will follow your recommendations and pursue the ad popup issue.
I did have one question, and please excuse my ignorance.
I keep reading everywhere about having a "rooted phone." Is my phone now considered "rooted" since I have enabled Developer Options, or is there something more involved?
Thank You,
WTH
That's the download mode. To go there you press the vol down key as well as home and power:https://www.hardreset.info/devices/samsung/samsung-g360f-galaxy-core-prime-lte/hardreset-second-method/#:~:text=Press Power button, until your,-- delete all user data".
If you correctly doing home+vol up+power, then maybe their info is incorrect. Try doing the opposite......hold the vol down button instead.
Unfortunately that model isn't listed for their app at HP Printers - Mobile Printing Solutions Compatible with HP Printers:
https://support.hp.com/us-en/document/c03722645
I also found this HP Print Service Plugin:
...but the list of compatible printers is the same as above so it's not compatible either.
Using Widows 7 may or may not be the cause but it is a bit antiquated. I read this
"After a little research, in device manager, I right clicked, went to Update Driver, Browse my computer for driver software, Let me pick from a list of available drivers on my computer, and selected one of the two "MTP USB Device" rather than "MTP Device". That got me back up and running."
Its worth a try, if that fails update Windows on pc.
The update installs the drivers but not select the correct one to install, you have to do that.
The "MTP USB Device" is the one to select
