Blue Light
- By ocnbrze
- Smartphones
- 5 Replies
can you get into download mode? if so maybe you can try flashing a firmware update.
Google you mean by that, you should intaken by itself, instead of chasing a wild ghost, or do the usb thing with your comp and just dump everything in that way, and work with your problem.I don't really do much cloud stuff. What I meant about googoo is all that play store, hangouts, etc. that I rarely if ever use but is apparently superglued into the phone by God knows who. It seems only rooting can take care of this, and I have had very little luck with that.
.Thanks. One dumb question:In fact, there is a whole collection of those Simple Mobile Tools apps.
If you look on F-Droid, they are all there.
Just do a search for 'Simple' and add what you are looking for...
gallery, dialer, contacts, calculator, calender, etc.
Be sure to also get the Thank You app, as it is an excellent way to sycronize the theme settings for the entire set.
All of the apps together are smaller in size than many single purpose apps.
I've had my phone for just over 2 years and its starting to fritz..
The fingerprint scanner's coating started to peel. I had to delete and re-scan my print to get it functional again, but in the end what I did is gently rub it with a cotton cloth [ handkerchief ] and removed the remaining coating. It now works reliably again. What a royal PIA this was until fixed.
I had a few random USB charging port "moisture detected" issues. I followed each of the suggestions below that I found around the intertubes, and I believe that the first time it corrected by accident, while the second time I found an actual solution. I believe this is being cause by looseness/damage to the male charge pin in the charging port causing a short that triggers the moisture sensor alert.
TRIED but did not work:
Blasting with air
Putting in AC vent
Different charging cables
Multiple restarts
Apps / Show System Apps / USB Settings / Storage / Clear cache
Apps / Show System Apps / Android system / Force stop
Removing 'recently installed or updated' Apps
Note: Would not charge even with phone powered off.
Had to get a wireless charger as phone went completely dead
WORKED:
Inserted probe under bottom edge of male connector w/in charging access port on phone and gently pried up ever so very slightly. Accepted charge immediately after doing this.
A better design for the charger port would be to have no free play up/down but instead a snug fit of the cable into the port.
I hope this helps others.
