Help Qi chargers
I have a sta card Samsung own Qi charger (the round type) I also have a magnetic Qi charger for the car which I have been unable to use as it requires me to stick a circular ring into the phone case so it sticks to the charger which normally wouldn't be a problem but the ring stops the Samsung charger from working.
Can anyone recommend a Qi charger for the house that will work if I have the metal ring installed into my phone so I can use the car charger also?
TIA
Help Whatsapp last seen time
Yes, I get that.
Tasker is your friend. It can perform actions based on the time or a condition such as the display coming on, probably a combination of the two. And some of the tasks it can perform include killing a specified app or returning to the home screen.
Other automation apps are available that can probably do the same thing, I just say Tasker because I have it installed so could quickly check what options it had.
Apps Possible function for an app?
I'm sorry, I don't need the code itself. I'm just wondering if something like this would be allowed to do in an app to be approved by the Google play store. I know there are rules and guidelines about things you can and can't include on an app. I don't want to create an app with certain functions only to have it rejected at time of review.
Sorry for the misunderstanding or miscommunication on my part.
Filter
