US996 on Oreo ULBL and rooted
I created a TAR backup of /data/media using TWRP/terminal booted into recovery.
I did a factory reset (actually just the DATA partition and then rebooted the phone into SYSTEM (Normal boot). Went thru all the "new phone" rigmarole successfully.
The went into recovery mode again and restored the TAR file. Figured it would restore the deice back to what it was before i was reset. NOPE!! Restoring the /data/media directory brought it back as though I had FACTORY RESET again.
I've done this before, (but probably on Nougat) and it used to work. Anybody have an idea; I'm stumped.
Thanks Boowho??
tasker entry and exit task behaviour
Hi,
I created a tasker profile with an entry and exit task:
entry task: When I connect to a wifi network a log is added to a file like: 200718-21:08 Conn: <AP-name> <no newline>
exit task: When I disconnect my exit task completes the log with something like: , disc after <period>.
This results in a log file with entries like:
200718-21:08 Conn: <AP-name>, disc after <period>.
Most of the time the logfile is fine but occasionally the log file is different, showing the entry task text multiple times before the exit task text.
It seems like the entry task is executed multiple times and I have no clue why.
Of course there are ways around but I still would like to understand the why. Can anyone explain?
Help Qi chargers
I have a sta card Samsung own Qi charger (the round type) I also have a magnetic Qi charger for the car which I have been unable to use as it requires me to stick a circular ring into the phone case so it sticks to the charger which normally wouldn't be a problem but the ring stops the Samsung charger from working.
Can anyone recommend a Qi charger for the house that will work if I have the metal ring installed into my phone so I can use the car charger also?
TIA
Help Whatsapp last seen time
Yes, I get that.
Tasker is your friend. It can perform actions based on the time or a condition such as the display coming on, probably a combination of the two. And some of the tasks it can perform include killing a specified app or returning to the home screen.
Other automation apps are available that can probably do the same thing, I just say Tasker because I have it installed so could quickly check what options it had.
Apps Possible function for an app?
I'm sorry, I don't need the code itself. I'm just wondering if something like this would be allowed to do in an app to be approved by the Google play store. I know there are rules and guidelines about things you can and can't include on an app. I don't want to create an app with certain functions only to have it rejected at time of review.
Sorry for the misunderstanding or miscommunication on my part.
Filter
