Accessories HUD display for car dash
I'm making a HUD display for my car's dash. I have the half-silvered acrylic mirror, a nice Car HUD app and a secure sticky mount for the phone, but I'm having trouble finding some hinges for the mirror that I can adjust the angle to get the best reflected image. suggestion please, Ideally under £15 GBP so I don't get stung for import duty/taxes.
Screen Share without triggering data useage? Next Best Phone Now???
That clears it up for me.
I just don't understand, why is Verizon apparently metering and counting data that's just passing between the phone and computer. This is something I've never come across myself. Because with my carriers and everyone else I know, the carrier meters data within their network for data that's uploaded/downloaded over 4G.
At least some US networks view tethering as a way of charging extra. It's not the first time I've seen that, though I'd hope it would fade at some point.
Help Leelbox MXQ PRO - how to override pre-loaded Netflix version?
Hi bleviton,
Yes. You may replace the file in there. I have just made mine work now to not reinstall the old v4 version.
I moved the Netflix.apk to another folder and the other version I have I moved into this bundled_uninstall_back-app folder and renamed it to Netflix.apk.
Then I installed it.
I tested a restart and also a turn-off-wait-20seconds-then-turn-on and the Netflix stayed as the version I have. No need to uninstall-v4-reinstall-new-version-relogin anymore.
No EQ on this phone?
puppykickr;
I don't think I could use the YouTube streaming app, as I don't have a data plan with TracFone. While the amount of data used for streaming music is much lower than for video, I would surely run through more than $10/mo in data usage. If music streaming ever becomes a thing for me, I will need to move away from TF and get with VZ, AT&T or other such carrier who offers unlimited data plans. But for now, I am saving $$$ using TF, even if I consider what I have been spending for music from iTunes (download, not streaming).
In the end, I probably won't keep Spotify once the 90-day free trial ends. I have always been, and will most likely continue to be a fan of purchase & download music from the likes of iTunes.
The main point was NewPipe.
It allows for downloading.
Find yourself some free Wi-Fi (at home, a hotel, a local Wal-Mart, a library, McDonald's, etc.) and have at it.
Safe mode loop
Welcome to Android Forums @Saddkid :)
I'm also uncertain what your mean by "Safe mode loop". Its a term used in reference to PS4
If a PlayStation 4 system is only able to boot into Safe Mode (creating a 'Safe Mode loop'), this is a sign that an error is preventing safe start up and so I'm assuming you're LG Aristo 3 is stuck in safe mode.
"To get out of Safe Mode, please try the following.
1. Touch and Hold the "Power" key.
2. Tap "Power Off".
3. Once the phone is off, Touch and Hold the "Power" key again to restart.
The phone should now be out of "Safe Mode".
If the "Safe Mode" is still running after you restart your phone, I would then check to make sure your "Volume Down" button is not stuck. Check to see if it has anything stuck in it as well, dust, etc. Anything like this can cause the phone to go into, and get stuck in, "Safe Mode".
If that doesn't work try this...
Use the "Status Bar" to turn off "Safe Mode'. Pull down (swipe) the "Status Bar" of your phone. Now tap the "Safe Mode" button. This should turn "Safe Mode" off. Now your phone will automatically restart, so that it boots up out of "Safe Mode".
And lastly...
If you want to get rid of/disable "Safe Mode".
1. First turn off the phone.
2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button.
3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe Mode: OFF" or something similar.
4. If you wanted re-enable it, simply repeat the steps above, and you should see "Safe mode: ON" rather than off."
If you have no choice but to factory reset your device be aware of Google FRP lock or youll be locked out of your device permanently.
https://www.google.com/amp/s/www.technipages.com/help-my-android-is-stuck-in-safe-mode/amp
Cell Phone Keeps Searching For Wi-Fi
I don't have "preferences" on my phone. There is "advanced Wi-Fi"; only thing "possible" is Notify whena open wi-fi- is available". I thought that meant when it finds it teels me and that's it. Perhaps not.I turned that off but it made no difference.
As for the router, it says it's connected to it so re-starting it shouldn't make a difference. And I don't want the hassle of re-starting the router and modem and maybe having a problem with the computer. I avoid touching things that are working.
even though it says connected it could still be the router. rebooting does nothing to your other devices. i periodically reboot my router with no issues as far as my other devices....it can't hurt and might help.
Filter
