Breaking Bad Fans let's talk withdrawals,Breaking Bad Rehab !!
Currently watching Better Call Saul Season 5 on Netflix, Jiimmy/Saul has really gone over to the dark side, Gus, Mike and Nacho are present and correct, as are the Cartel. I think this season may end with a slight overlap with Breaking Bad season 1.
I am starting to wonder what would ever happen to Jimmy if he accepted, Howard's request, instead of being himself?
Galaxy S7 Broken Screen & Power Button
Hello,
Okay so i have two phones:
Phone 1: Galaxy S7 Broken Screen & Power Button (I think fingerprint is set up )
Phone 2: Galaxy S7 Broken Screen (No Passcode/Swipe)
Okay so i have an adaptor coming today so i can use the mouseto swipe access on phone 2.
The problem comes with phone number 1 i am thinking of changing the mother board from phone 1 to phone 2 once i have backed up the data. How ever i am unsure if this will work.
Is the phones internal memory situated in thephones main motherboard orr...?
Samsung Galaxy S7 Broken Screen & Power Button
Hello,
fAQaiDA2v95qiUvK8
Gave it a try: okay but needs work
Do you intentionally put the controls near the ad in hopes of more clicks?
- Placing ad banners, as well as controls at the bottom of the screen, is a standard practice used in the vast majority of such (and not only) apps. Users will pay attention to such a banner much more than placing them at the top of the screen, for example. At the same time, I try to prevent accidental clicks - controls and the banner are separated by a non-clickable information line (TIMER ... MIXER ... TIME ...). In this matter, I follow Google’s recommendations, although in many popular apps, even those marked with the "Editor’s Choice" sign, you can see the banner placed immediately next to the controls.
https://support.google.com/admob/answer/6275345?hl=en
"Close proximity of banner ads to other elements within an app is one of the biggest causes of accidental clicks. To avoid accidental clicks, banner ads should not be placed immediately next to interactive elements and app content [...] This banner ad placement can put your app or your account at risk if too many accidental clicks occur, and we recommend against such an implementation."
Nice work overall!
- Thanks!
Help Is Someone In My Biz
My Motorola g6 has been hacked and they can control it and I can't figure out how to fix this and who hacked my phone
Make sure it's only you that has access to your Google account. Change your password, and enable two factor login. Far more likely it's your Google account that's been compromised, rather than someone hacking the phone itself. Unless someone else has unsupervised physical access to your phone?
Need Information
how did you update the phone? were you getting 3g/4g before? have you talked to your carrier about it?
I got it on the Phone through system updates option prior to that I was getting 4G option. Actually a friend on mine works for Vodafone and he himself came down at my place to check the device and everything was fine. Also, on my other devices it gives me 4G with the same SIM
Rooting an OPPO R7plusf, Android 5.1.1
always do your research at xda, if you ever want to root your phone.
i did it for you:
https://forum.xda-developers.com/r7-plus/general/guide-root-oppo-r7-r7-plus-one-click-t3212055
please read the guide thoroughly before attempting to root. i would also recommend that you read all the posts in the thread. sometimes they have some tips that's not in the guide.
i would also recommend that you ask any questions here as xda can be full of drama queens.
keep us posted and good luck;)
Filter
