Motorola Moto G Power Not Recognizing SD Card Reader
With a Pixel phone to change USB setting, ie, from charging to data
You can set the Default USB configuration in the Settings > System > Developer options.
To unhide the Developer options menu:
  1. Go to "Settings", then tap "About device" or "About phone".
  2. Scroll down, then tap "Build number" seven times
This is really weird. When I went to developer options and the USB configuration, no data transfer was selected. I had turned the google photos backup back on thinking that was the problem to begin with. I selected the file transfer option and stuck my card reader back in there with an empty SD card. It mounted and wanted to reformat the card so I let it. Then, I went back and turned google photos backup off again and stuck the SD card with some photos on it in there and it's right back to where it was. It won't even mount it again. I even tried putting the card that it reformatted back in the reader, no go. The USB configuration is still set to the file transfer selection.
(Java) Android IR Blaster app
Hello everyone,
this is my first thread so I hope that this will bring me to a solution.
I recently bought a SMART IR Blaster for my phone that connects via otg port. I'm currently making an app to control every
kind of device of all brands. I installed the app made for this IR and works perfectly, so I wanted to decompile it and get some code to implement the IR in my app. I tried to recreate many functions from com.esmart.ir package and made the permission request but it didn't work...
The app is called Ocrustar, available on google play store.
I'll pay 10€ via paypal if anyone can send me a working method, possible in java :)
No Wifi
The simple option is to try another Android distribution (such as FydeOS). That's what I did with my Surface Go 3: I tried a few Android distributions, until I found one that worked right. That said, I have two questions:
#1: Why do you want to install Android onto this computer?
#2: Is this computer a tablet-laptop hybrid? That is: Does it have a touch-screen, and can the keyboard fold back so that the computer transforms from a laptop into a tablet?
Greatest Moments in AF HISTORY?!
The HTC Droid Incredible launch gets my vote. And after all of the hype and everyone waiting to get the phone, it lived up to and was more than anyone dreamed. I spent my first month here sharing the misery with everyone waiting to get their Dink. It was the friends I made while waiting that cemented my love for these forums. It was that foundation and the wonderful members that followed that has kept me here.
Accessories New microSD going read-only
I haven't bought an SD card since like 2013 so I'm luckily unaffected. I've been reusing the same cards since Android 2.3 was launched.
That's fine, so long as you don't need the higher capacity and faster speed of modern disks. But SD cards are cheap enough that, when you start worrying about space, I'd recommend buying a larger more modern one. Just buy it directly from SanDisk (or another reputable manufacturer)!
Updates
I have a Nokia T20. Let me check mine and I'll let you know what mine says
I'm Android 12 Security update August 5, 2023
After getting the Android 12 update back in November 2022, the tablet is finally receiving its official Android 13 update. Aug 8, 2023
https://www.gizmochina.com/2023/08/08/nokia-t20-android-13-update/
As per tip received from our readers the Android 13 update for Nokia T20 is available in Indian market. The update however may be available in other markets too.
The Android 13 Build V3.220 comes with Android July security patch update for Nokia T20. The update is a huge 2.74GB in size.
Ok, thanks, I'll keep checking
Android Wear Tips & Tricks
1. Custom Watch Faces: Personalize your Android Wear by choosing from a variety of watch faces from the Play Store.
2. Voice Commands: Utilize "OK Google" for quick actions like setting reminders or sending messages.
3. Gestures: Navigate through notifications with wrist gestures, making it easier to manage your device on the go.
4. Battery Saver Mode: Enable this mode to extend your watch's battery life when needed.
5. App Management: Use the Android Wear app on your smartphone to manage and customize apps on your smartwatch.
Filter
