Playlist files keep coming back
- By PaulWarning
- Smartphones
- 3 Replies
I solved the problem on my phone by deleting the M3U file out of the album folder
I would guess you are struggling with outdated technology in your vehicles.hummmmm what about it?????Mobile network
ok just to be clear, this is a prepaid phone, correct? not sure how you can carrier unlock the phone that is prepaid. that is something that usually is done by your carrier. there are plenty of services online, but you will have to pay for it.
He is, but also a badass. Still much better than the previous evil ***** of a President.Sounds like he's a bit of an ass.
From the first post it's unlikely that residual water is the problem. So nothing to lose by trying, but I think it's a long shot.
BTW rice is recommended as a drying agent as it's something Western homes are likely to have. Couscous is apparently better, and of course silica gel if you have it would be better yet.
The problem is, what if there is corrosion damage somewhere where you can't see it, e.g. inside the display panel rather than on the connector, inside some other component, or in some small contact on a chip on the mainboard (which may be under the chip)? A washing machine will be a pretty hostile environment (hot, very impure water for an extended period), so I'd not rule anything out. What I'm saying is that even if it's a long shot you might want to try the drying anyway, because at least that's cheap. The risk with buying a new display is that if there's a problem on the mainboard it will have been a waste of money.
The problem is how to test whether it is just the display? Maybe try booting the phone and then calling it or something, to see whether it will respond at all (i.e. whether the display is the only problem)? Unfortunately the S6 series had no MHL or USB to HDMI support, so there's no simple way to mirror the display to a TV, which would be an easy way of confirming whether the rest was working (Chromecasts are useless for this because you need to set it up, which you can't do with a blank screen - wired mirroring is just much, much more useful for diagnostics or data rescue with a dead screen, but not something Samsung regarded as a priority).
anybody know what the code is for is for restoring the phone # and min # in the dialer?
I'd get that info from the boost mobile community private mail, but they turned it off due to the stupid virus. so I can't retrieve it.
ZTE had me do a factory reset of the phone before I FED EX the phone for repair.
the phone #, I recorded, but I forgot to record the MIN #. not sure what to do about that one.
What of the recent reviews complaining that it takes an extremely long time for the gallery to load and display properly? And others saying that it magically deleted thousands of photos? I'd love to find a better gallery app than the stock version... even though my photos are backed up (in both Photos AND OneDrive), I'd rather not lose them unless I specifically delete them...
In the past year, Louis Rossman, (sp?) an Apple repair guy and YouTube personality, has been all over the country advocating for right to repair, including my home state of Washington. Wish I could've met him, seems like a straight shooter.
I have a Galaxy A40 with Android 10 installed. After a system update i'm not able to synch WMP playlist to my smartphone. I see a playlist in the Playlists folder but it is empty.
Please advice
Kind regards
Thanks man! You're the best! I appreciate the assistance!😁😁😁😁
So, I'm trying to tether my Acer Chromebook to my mobile phone using 4G data connection. My laptop shows connected with a strong signal but I have no internet on it. My phone shows that my Chromebook is connected. It makes no sense b/c both devices show they are connected with a strong signal. My phone is an LG X Charge android OS. What could be the problem?? Thanks!!!
