Easy, fast and free - Best QR scanners app for your smartphones.
Only with mobile phones that support photo taking, you can quickly read the information behind the barcode / QR code in just a few seconds. In addition, you can create personalized QR /Barcode codes with your information easily and quickly.
QR code was designed with camera permission. If you care about security, this is the code scanning application just for you.
HOW THE APP WORKS
Scan all kinds of QR codes and barcodes in one step: open the app and move the camera to the location with the QR code / barcode you want to scan. When scanning the QR code, if the code contains the URL, you can open it Browse to the site by pressing the browser button. If the code contains only text, you can see it immediately.
Not only is this a QR code scanner, it also gives you lots of interesting features like saving scan history so you can review any when you want. This code scanner app not only helps you scan QR codes, but also other types of codes. In addition, you can share your scan results easily with just a push of a button.
KEY FEATURE
Scan all QR codes and barcodes with strong decoding speed: The only thing you need to do is move the camera to focus on the QRcode / Barcode object.
Create your own QR code/ Barcode (To access this feature, you are required to pay or to watch the rewarded advertisement)
You can scan QR codes or barcodes from the image library
Support scanning QR codes in the dark with the flashlight
Save your QR code scan history
Barcode scanner app can scan and read all kinds of QR codes including: Text, contact, email, product, sms, URL, wifi,...
You can share the results after scanning with your friends on social networking sites.
QR Code Reader is compatible with Android versions 4.4 and above.
DEVELOPMENT ACTIVITIES
QR and Barcode scanner app is still in development, if you have any feedback or suggestions, please write to us at
qrcode@ecomobile.vn. We look forward to hearing from you!
