"Home" Setting
Thanks, svim. I called ZTE a few days ago and, as usual, the Technical Support guy was stumped but suggested a complete factory data reset! I said thanks anyway. If my money is right, I'll be buying a new android phone from Ebay, etc., so will leave this phone alone until I get it's data put on a new phone. I will try their support page, though. Thank you very much! Jeffrey Walker (PS: am I supposed to create a cool screen name? If so, how do I do that?
FAT32 & EXT4 Partitions For Android Internal Storage?
Thanks guys, I may have over complicated this myself. What about if I made two partitions (both FAT32), using one to store my Roms. Could I then use the second partition only as android internal storage?
you will need to gain root access to do this.....so unless your device can be rooted, nothing you want to achieve is possible.
USB-C to HDMI
With the Chromecast, I can send almost anything to my TV. Most video apps have the ability to send their movies to the Chromecast. If they don't, like IMDB (international movie data base), I can go into the phones Settings, Network, Screen Sharing. When I turn it on, my phone's screen is sent to my TV. You may be able to do the same with your cable but then you can't do anything else without interrupting the video. Your TV becomes your phone's screen so you can do exactly the same things you do without the cable. But just like your unconnected phone, when your phone rings, the video stops to answer your phone. View attachment 148841
Ok ok that's actually really cool when I get the internet at home I'll try that
Help URGENT** S health app
WoW, thats very
You were very right!, I thought my S Health was working "flawlessly"..as it turned out..it was not!..I thought it was because it was counting my steps fine..but I got inside and the blood pressure monitor allowed new just to "record" my measurements..NOT to actually measure the blood pressure by finger print scan..
I dag further(because that's my nature..ask Mr Javi..lol)..and I came out with a solution..
I changed my version again(you are only allowed to change it if you are rooted..and I know you are..you mentioned it)
This is the one that did the trick(exhibits1)
The one I thought was working fine I extracted from my former Note5..
And if you pay attention the one I just installed and I have previously extracted from my former S5 and its the one letting me use the red light finger print scanner..get that version and you will be good.
But here's the thing..even if you find this particular version(unfortunately it's against the Forum rules to share this type of files..other wise I gladly would send to your way) you can't just install on top of the current one you have..you have to delete the older one and port the new one..[/QUOT]
Thats pretty impressive my friend
lost imei
No I did not attempt because of the different model. Says for xt1771-xt1773 and references the Nicholas model. Again mine is Owens xt1775
but i DID find this little gem. https://support.lenovo.com/rs/en/do...00&irgwc=1&PID=27795&acid=ww:affiliate:bv0as6. it is a moto smart assistant . use the rescue option to bring your xt1775,1776 back to stock, imei and everything back!! very easy and worked flawlessly
Battery charging very slow
If changig cords did not solve the issue, then it is time to look at the charger itself.
If you have another charger, use the cord with the highest milliamp capacity from your earlier tests, and try it with the different charger.
If you are still experiencing the problem, then you need a flashlight, and maybe a magnifying glass as well.
You should inspect the jack on the phone itself.
The contacts are very small, and any dust or debris that gets in there can cause a poor connection.
You could try some compressed air (the same as what is used on computers) to blow out the jack.
A toothpick can be used VERY CAREFULLY AND GENTLY to remove anything that cannot be removed otherwise.
Remember that these contacts are very small, fragile, and easy to damage!
Help Android Phone randomly goes crazy
but it doesn't do that all the time. It does that rarely
Your post described it as happening often.
In fact, 'every time' was a phrase that was stated.
But that doesn't matter.
The screen reacts to electrical change, not actually touch.
There is electrical change as your finger gets near the screen- even before actual contact is made.
Due to abuse, the adjustment has been skewed so that the screen reacts before it is actually touched.
I actually have experienced this as well, when my finger was damp.
The screen reacted before I had even touched it.
As soon as I dried my hand, it acted normal again.
New App: Home Workout - No Equipment (Version 1.0.31)
WHAT'S NEW
• Fix bug
EXTRA INFO
  • Rating: 4.8
  • Installs: 50,000,000+
  • Download Size: 16M
  • Version: 1.0.31
DESCRIPTION
Home Workouts provides daily workout routines for all your main muscle groups. In just a few minutes a day, you can build muscles and keep fitness at home without having to go to the gym. No equipment or coach needed, all exercises can be performed with just your body weight.
The app has workouts for your abs, chest, legs, arms and butt as well as full body workouts. All the workouts are designed by experts. None of them need equipment, so there's no need to go to the gym. Even though it just takes a few minutes a day, it can effectively tone your muscles and help you get six pack abs at home.
The warm-up and stretching routines are designed to make sure you exercise in a scientific way. With animations and video guidance for each exercise, you can make sure you use the right form during each exercise.
Stick with our home workouts, and you will notice a change in your body in just a few short weeks.
Features
*Warm-up and stretching routines
*Records training progress automatically
*The chart tracks your weight trends
*Customize your workout reminders
*Detailed video and animation guides
*Lose weight with a personal trainer
*Share with your friends on social media
Bodybuilding App
Looking for a bodybuilding app? No satisfied bodybuilding app? Try our build muscle app! This build muscle app has effective muscle building workout, and all muscle building workout is designed by expert.
Strength Training App
It's not only just a build muscle app, but also a strength training app. If you are still looking for muscle building workout, muscle building apps or strength training app, this muscle building apps is the best one you can find among the muscle building apps.
Home Workouts for Men
Want effective home workouts for men? We provide different home workouts for men to workout at home. The home workout for men is proven to help you get six pack abs in a short time. You'll find the home workout for men that most suitable for you. Try our home workout for men now!
Fat Burning Workouts & Hiit Workouts
The best fat burning workouts & hiit workouts for better body shape. Burn calories with fat burning workouts, and combine with hiit workouts to get the best results.
Multiple Exercises
Push ups, squats, sit ups, plank, crunch, wall sit, jumping jacks, punch, triceps dips, lunges...
Fitness Coach
The best fitness apps and workout apps. All sport and gym workout in this workout apps and fitness apps are designed by professional fitness coach. Sport and gym workout guide through the exercise, gym workout and sport, just like having a personal fitness coach in your pocket!
Filter
