What App Notification Has"Heart with Dots Icon?"
- By atx_tam
- Apps & Games
- 4 Replies
Ahhh I was hoping not.
you will need to gain root access to do this.....so unless your device can be rooted, nothing you want to achieve is possible.Thanks guys, I may have over complicated this myself. What about if I made two partitions (both FAT32), using one to store my Roms. Could I then use the second partition only as android internal storage?
Ok ok that's actually really cool when I get the internet at home I'll try thatWith the Chromecast, I can send almost anything to my TV. Most video apps have the ability to send their movies to the Chromecast. If they don't, like IMDB (international movie data base), I can go into the phones Settings, Network, Screen Sharing. When I turn it on, my phone's screen is sent to my TV. You may be able to do the same with your cable but then you can't do anything else without interrupting the video. Your TV becomes your phone's screen so you can do exactly the same things you do without the cable. But just like your unconnected phone, when your phone rings, the video stops to answer your phone. View attachment 148841
You were very right!, I thought my S Health was working "flawlessly"..as it turned out..it was not!..I thought it was because it was counting my steps fine..but I got inside and the blood pressure monitor allowed new just to "record" my measurements..NOT to actually measure the blood pressure by finger print scan..
I dag further(because that's my nature..ask Mr Javi..lol)..and I came out with a solution..
I changed my version again(you are only allowed to change it if you are rooted..and I know you are..you mentioned it)
This is the one that did the trick(exhibits1)
The one I thought was working fine I extracted from my former Note5..
And if you pay attention the one I just installed and I have previously extracted from my former S5 and its the one letting me use the red light finger print scanner..get that version and you will be good.
But here's the thing..even if you find this particular version(unfortunately it's against the Forum rules to share this type of files..other wise I gladly would send to your way) you can't just install on top of the current one you have..you have to delete the older one and port the new one..[/QUOT]
Thats pretty impressive my friend
