Find an App/Game Forum using Package Name
- By NightAngel79
- Announcements
- 2 Replies
This has potential!
Here's a link where you can actually buy accessories for the S20 line from Samsung.
https://www.samsung.com/us/mobile/mobile-accessories/all-mobile-accessories/
Here is the exact notification I get (I get a toast notification too, but I can't screenshot that becuase it is on top of the app I restricted screenshots ofWhat app are you taking a screenshot of? I think I have a permission like that for Thenticate, the app I use for 2FA.
)Yeah no issues since it was fixed
This doesnt require you to have OEM Unlock enabledDetailed tutorial, I have some questions:
We must have OEM unlocked for this?
Will this bypass FRP?
A Factory Reset to fix a voicemail issue? Well, the nuclear option is one way to fix a problem. Be sure to back up all your data first, and be prepared to go through the whole setup process if you've done a lot of changes in your Settings menu. I'd go about fixing your problem from the least drastic then to more extreme measures, but if the opposite way works and you don't lose anything than a Reset is a nice way to clean out a lot of other issues that might have been building up over time.Thanks Svim - problem started in the last week. Carrier is Straight Talk. They suggest factory reset.
An app called
Addons Detector
https://addons-detector.en.uptodown.com/android
will give you the information on every permission for every app on your device, as well as other info.
