android box with android tv os
hey guys im looking for a android tv box that runs the official Android tv os, so it will be optimized to run on a tv, im wanting a cheap option maybe up to 50 dollars on ebay or Amazon, needs
usb ports, right now i have a android tv box running stock android and a roku but im not happy with either one, might consider Amazon fire tv box, as long as its android and has usb ports thanks
Photo Editor - Pip camera - Sparkle Effect (Blur)
Photo Editor - Pip Camera - Sparkle Effect (Blur) best app to make your photo fully attractive and heart touching. You can use four tools in this app with many effects like photo frames, overlays effects, twinkle effects, photo cropping, photo filters and photo borders in this best Photo Editor App - Pip Camera - Sparkle Effect (Blur).
Sparkle Photo Effects is a user friendly app, you can select the picture from gallery and brush the area on which you want to add sparkle effect, photo focus, shimmer effect, glitter effect, twinkle effects etc. You can also add different categories of stickers, emoji's and add your personalized different text styles with latest fonts and colors combination.
In addition, Pip camera photo editor is another magical app tool which make your photos beautiful and creative. You can shape up your photos like camera, book, mirror, heart, frames, and much more shape styles pip effects by using pip camera photo editor effect tool. Pip camera photo editor app will reinvent your photos in a way to get the super blur attention and unbeatable pip focus effect. You can also blur or de-blur your photo after pip effect in pip camera or pip photo editor. You shouldn’t have to miss this amazing photo editing pip camera tool which has the ability to make your picture look more attractive.
Help Roaming Indicator Off stuck on notification bar
Hello, I just switched from Sprint to a Verizon MVNO and a few weird things are happening and I can't seem to find a lot of info or help for it. After sticking the new SIM in, it said it was connecting to "." and then it updated apps for "." After that, where Sprint or US Mobile should be located at the top left, it says "Roaming Indicator Off" instead. In the network settings it says the network provider is "roaming indicator off" lol.
The APN list is a dozen of Verizon related ones, and Verizon Internet is selected. I was told by support to use https://www.4gapn.com/us/en/verizon APN settings to add another one. The top left then read "Searching for Service" and I had LTE while it was searching but after 2 or so minutes it shut off and read "Emergency calls Only". I've tried putting the Sprint sim back in and fiddling with the settings there and switching back to the US Mobile sim, and it started to try to activate to the network but eventually failed and gave error code 6604. I'm assuming it was trying to connect to Sprint? Someone suggested taking a Verizon sim and seeing if that can install the Verizon personality on the phone, since it was still running Sprint OMADM and was in an in-between stage of being both Sprint and Verizon. I found an old Verizon droid and put the sim in. It got it to recognize as a Verizon sim, and now it boots up saying Hello Verizon, downloaded the apps and waited a while. Started to look good, it said it couldn't activate service but I'm assuming because there isn't any on it? Popped the US Mobile sim back in and still saying Roaming Indicator Off. MMS still doesn't work either. Also noticed I have a new APN, LTE Verizon Internet. I have another phone with an active Verizon service on it, but I'm not sure if that will work either. Maybe I'm more in Verizon land than no man's land now.. At least I'm getting somewhere.
I should also add this is on a Galaxy S9+ and was leased, I bought it out over a week ago. MMS is also not working. Data, and VoLTE are though.
Edit onboard dictionary
To adjust the keyboard dictionary on your LG G5 try going into:
  • Swipe down from top- tap settings
  • Select General > Language & keyboard
    • Or look for Personal > Language & keyboard
  • Look for "Personal Dictionary"
You should be able to delete words from your dictionary from here.
If you cannot- please upload screenshots showing which options you have.
Tap to translate
OK after much research, it appears that Google has crippled it's own translate app in 10. The "Tap to translate" button does not appear when copying text, but has been replaced by a "floating" icon which is present on the home screen all the time, and is not easy to use.. This CAN be turned on and off, but the settings are very complex and confusing.
I live in Mexico and this capability was very important to me, for translating texts and emails from Spanish, and vice-versa. Now my Android phone basically is the same as an iPhone in this respect.
I wish I had never allowed the update to Android 10.....
Home screen panel location
I recently made some Display Settings changes to my S10+ and found that now when I push the Home button (middle button at the bottom of the screen) the phone returns to a different panel than before. Before it returned to panel 1 where I had all of my main apps but after the settings changes it started to return to panel 3 where I had my least used apps.
I tried to find some place in the settings that controlled which panel was displayed when the Home button was pressed but could not find anything. Can anyone help me? The only way I have been able to address this is to move all of my main apps to panel 3 but that seems like the wrong way to fix this. I think I should be able to set which panel is the Home panel but don't see where or how to do that.
Any help would be appreciated.
Switching Paid App To In App Purchase
I don't know the technical details of how to implement it, but I've used several apps which have made a similar transition. The general flow seems to have been to convert the paid app into a stub application which only functions as a license key. When a user installs the new free app, it checks to see if the paid app is already installed; if so, it unlocks the IAP features without requiring the user to purchase again.
The downside (for users) is that since there isn't an actual purchase happening there's no server-side persistence of the feature unlock; the user will have to remember to install the paid app and the free one if they factory reset or get a new phone. And of course the downside from the developer perspective is that the reviews/ratings don't transfer from the established paid app to the new free IAP-powered one.
There may be other ways to handle this but that's the approach I've seen used the most - and, again, not a developer so don't know the technical details of how to pull it off.
Filter
