Help Why didn't lock screen pattern or backup PIN work today?
- By puppykickr
- Smartphones
- 1 Replies
Restarting an Android is like giving it an enema, a vitamin drink, a caffiene pill, and a massage all at once!
Same here. I do not use my google drive at all either. Mostly dropbox.Much like @Steven58 and @Unforgiven I had no idea such a thing existed, I probably would have used it.
What's the method of communication for getting 'called': phone call, text message, e-mail, slack, etc...?
Great, that worked, thanksTry reinstalling that same app, and no, you don't need to even start it up. Just install the app, then go into your Settings >> Apps menu, find and open the entry for that app, tap on 'Force stop' if it is still running, and then find the Clear data button and tap on that. Using Clear data removes that app's configuration and settings files, along with its cache. With some apps, using just the Uninstall button removes most of the app but not necessarily its settings. Clear data 'should remove it all. You need to install the app just to access that 'Clear data' option.
And don't forge to just restart your Note 8 afterwards, just to be sure anything relative to that app lurking in RAM is wiped.
Yes, it should be that some resource files which would be downloaded online while the app initializes are unavailable now.That game is discontinued. And the online download resource it needs is no longer there.
settings>apps>calendar>clear cacheUummmmmm I use a Samsung tablet....how do I do that???
Thank you!Four vowels and only two consonants, one being X, made it hard for me to spell, but I think I got it.Good luck.
You're most likely to get help with this by posting on our Android Development board.i am getting something like OnUpgrade event but don't how to call it and where to set oldversion and newversion values.
Currently, I am using MI note 7 pro.What device are you currently using to play PUBG? So we might have a better idea of what would be an upgrade for you.
