Messenger notification icon no longer appearing on home screen
not sure how that will help the op as that just adds the app to the home screen. it does not help the op get a popup message of a new text. plus this thread was started last year.....no reply from the op, so hopefully the issue got fixed.
I ran into this problem after replacing phone with newer model and using software to move all my apps and data. Discovered the missing setting was to grant the Messenger app permission to Draw Over Other Apps.
Unknown Trackers scan option A32-4G Android 13
When you say "same software version" what exactly do you mean: same Android or One UI version, or both have the same most recent update? This feature is only a couple of months old, so most likely was only added in a recent update. If one person is better at applying updates than another then that could explain it. Maybe check for software updates on both phones and install any that are waiting.
I'm assuming that both are unlocked models or both are with the same carrier. If they have carrier software and are on different carriers it's also possible that one would receive an update sooner than the other.
Source for attaching photos
I made the terrible mistake of selecting a file in Google Drive to attach to a tweet. Now whenever I want to attach a file to anything it opens Drive. How can I restore the old behavior of opening Files on the local device?
Galaxy Tab S7 SM-T870, Android 13,
... Now whenever I want to attach a file to anything it opens Drive....
When I attach a file to new mail in my Outlook app, it pops up a menu that lets me pick a file from Files or Gallery.
Auto resize wallpaper when going to/from landscape/portrait mode?
i am too lazy to use wallpapers that i make or find on the web. for me i use Zedge for all of my wallpapers and also for my ringtones. Zedge will resize the photo to your phone.....though i have a found some that will not.
Help Why does ringer volume keep going down?
first off welcome to AF!!!!!!!!!!!!!!!!!!
I am a Computer Science major and a cell phone user since 1992, and a mobile phone user since 1982. I don't like smartphones any more and hate the tracking. I would be just as happy to go back to a satchel phone and do without all of the BS.
that is all fine and dandy, but what does your post have to do with the op which is about ringer volume going down? plus this thread is from 2019.
Help Bricked(?) Huawei WAS-LX1A
"Rooted" refers to the state of the ROM, i.e. whether it has been modified so that the user can grant admin rights to user-installed apps. So if the ROM part of the sequence of files you flashed was stock (official software) then your phone will not be rooted. My guess would be that it isn't rooted, since a process that replaces TWRP with a stock recovery and locks the bootloader doesn't sound like one that will install a rooted ROM.
I upgraded the phone starting from WAS-LX1AC432B182 up to WAS-LX1AC432B210. Now it doesn't find new updates and I'm currently stuck with Android 7 and Emui 5.1.1.
Is it possible that the Warsaw-L21A C432B182 EU SERVICE is a special version for technical support and my phone and HiSuite can't find me the Android 8 update for this reason?
I'm not familiar with modifying Huawei phones, so can't say. But yes, it is possible that the update path for one model, or one firmware version of one model, doesn't go as high as for another. If you've been flashing firmware for one model onto a different model it's also not impossible that the official update process looks at your device and says "hang on, something's not right here" and refuses to install any further updates, though in that case I'd think it more likely that it would apply no updates at all than that it would update so far and no further.
EDIT:
Is it normal that the smartphone version has remained WAS-LX1A even using a WAS-L21A forced update firmware? It probably comes from the OEMinfo put.
Well the "normal" thing that happens if you succeed in flashing a different model's firmware onto a phone is that the phone is hard-bricked ;).
I guess this is a device where they built one set of hardware and then disabled the dual SIM functionality via firmware in some regions or for some carriers, because that's the only way I can see what you've done here actually working. But my point is that being able to do this is a special case, so probably the only people who could say with confidence what to expect would be those who have performed similar mods on this model, or at least another Huawei of similar age. You could ask in one of those XDA threads, if there is anyone still watching them, but it's not a question I can answer.
Samsung tablet s8 Ultra
I don't know where in Europe your tablet came from, but European frequencies are fairly uniform so I'll assume that a UK model is representative. In which case according to Samsung it should support LTE bands 1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 20, 25, 26, 28 32 and 66, while according to an ATT forum post they use bands 2, 4, 5, 12, 14, 17, 29 and 30, with 12 and 17 being the main bands. In which case you should have LTE compatibility. Samsung also claim that it should support 5G bands n5 and n77, which are used by ATT (plus others that are not).
So if the 3 sources I used here are all accurate (and that's not certain: manufacturers have themselves been known to post inaccurate information by copy-pasting between their regional sites!) you should be able to use 4G or 5G, provided you have coverage with the right bands.
You say that the APN settings change when you insert the SIM: do those settings look correct for ATT?
Play Music
there's 50/50 success in using an old version of Google Play Music to play files offline if you're just that used to its UI, and some have a fraction of success in using older versions to stream, but since it's pretty much EOL by Google, that might not last much longer. If anything, it cemented my view against depeding on any of their apps long-term, yes, including Maps and YouTube, as anything they get their hands on dies eventually, and I am of the type who not only tries to buy for life, but keep apps of certain types for life.
I got one tablet, a Galaxy Note 8.0 LTE from 2013, that surprisingly still connects to the online portion of Play Music, since it's showing Roy D Mercer queued up on it, which is a YouTube Music playlist I created some time back, but it no longer gets updates to the OS and Google Play Services so it can't 'force' me to stop using it. Will it last? Nope...probably not. Which is why I don't use it.
Mystery notifications
The best advice I can give you is leave the case off for a few days and hopefully it will correct itself, but something might be permanently bent.
I have seen the tight case issue come up a few times over the years going all the way back to Palm phones. Sometimes leaving the case off for a while corrects the problem, sometimes it doesn't.
Looks like you were right. Removing the case for a day and putting it back on has eliminated the mystery notifications. So far . . .
YOU DA MAN
New free strategy game - Landrule
Hey Pixamark:
First off, great game!
I have an issue where certain games have been corrupted and cannot be cleared from "My Games." When I try to click on them, it says something like "Cannot find user slot" and there is no option to leave the game.
How can I clear these out? It is preventing me from playing multiple multiplayer games.
Thanks!
Did you ever get am answer? I'm having the same issue.
How to enable restricted settings?
Hello, I have this App called Cube ACR to record calls. I mainly record calls to help remember stuff like appointment times and such.
However since i have android 13, i need to allow restricted settings on the app. But when i go to the app, the 3 dots (more settings) is not there to turn off restrictive settings. What can i do?
I have a galaxy 22+ and i have attached a screenshot of the app information.
Total by Verizon BAD?
speedtest.net's credibility was debunked for me the very instant they claimed I had 25mbps down when in reality I barely had enough to stream 360p YouTube and it took over a week to download the day-one patch to Fallout 4. If anything my internet experience and cellular experience only solidifies my love of physical media over streaming, owning my own music and keeping anything digital on my device over some cloud that always disippates anyway, and not depending so heavily on being online. Many of my PCs are air-gapped now, and only two remain in active service at home, one that is air-gapped and this one which only seems to be used for this forum and some Reddit reads.
The last modern bits in my home are a Nest Audio and hub, one Home speaker, a really old Echo Dot, Nintendo Switch (which works offline better than a PS4 or Xbox) and my Z Flip 4. Everything else has gone vintage or stays stuck in 2009-10
No thanks, my own way of determining my internet speed seems to work best over some rando app.
Filter
