Rabbit Doubt
- By olbriar
- Forum Games
- 9 Replies
The tread was started nine years ago. Obviously, at that time, the op lacked participants to play the game. It is anyone's guess why he drifted away from AF and not returned.
i think he means for the sim lock not the lockscreen.
maybe this article might help:
https://www.digitalcitizen.life/how-change-or-remove-sim-pin-android-2-steps
thnx lunatic59. i found good answer in funplus website, my amount is automatically recover from my carrier.Hi and welcome to android forums.
Your carrier was correct. Even though the transaction was handled through them, the people you need to contact are the developers of the game. This is their website https://funplus.aihelp.net/elva/FAQ/FAQList.aspx?l=en&SectionID=0&pf_app_id=993 and the play store lists contact_koa@funplus.com as the email contact.
If all else fails, go to crucial's website and use their system scanner. It's pretty good at figuring out what type of memory is compatible with your specific system, and what the max it could feasibly support.One question: how exactly can I know which RAM fits for my laptop? I have an old Acer Aspire E.
First, I do use Android devices, just not Samsung ones.
Second, I do not source news from Google.
Third, if it is E-Mail contacts that are coming up, then it is your e-mail app that is providing the pop-ups.
Look inside that app for share options inside of the settings.
Example:
Let's say that you want to share any given article onto your Facebook account.
In your browser, there should be a share option.
In the browser, bot the news article itself.
Select this, and look for the option 'Copy To Clipboard'.
Select that, and then open your Facebook app (or a wrapper app, as I do) and then long press the area where you would post something.
The 'Paste' option should appear- select it.
Your news article should now appear, and you can post it.
Maybe this is a few more steps than just using the links provided with the news stories, but as you can see, those links are often problematic.
I had so much trouble with those type links that I refuse to even acknowlege that they exist unless someone else has problems with them too and needs tofind a way around them.
There are a few browsers that are very secure and very fast, that are so much better than what is stock on Android.
If you have trouble finding the 'share' feature in your browser, I would suggest Lightning, FOSS Browser, or Smart Cookie (all are on F-Droid) as excellent third party browsers that fast, simple, and secure.
They all rely upon an app called Android System Webview, which is a built in app on Android devices.
You probably mean that it was hard reset. If it was factory reset done from within the phone, frp would not have been tripped. If frp was tripped then there is not much you can do at this point. Make this one a lesson learned. There are some software out there that claim to be able to bypass FRP, but I think most are scams..... so be careful.Recently bought Revvl and the previous owner factory reset it and now I'm unable to get past the frp. previous owner had also completely disappeared and wont answer calls or texts. Please help
Source code for lucid 2
https://www.lg.com/global/support/opensource/opensourceList?types=ALL&search=vs870
Source code for lucid 3
https://www.lg.com/global/support/opensource/opensourceList?types=ALL&search=vs876
Here's the kdz for the lucid 3
http://zhidao.baidubbs.gaodi.net/forum.php?mod=viewthread&tid=665309
Good luck.
If you cannot install GApps, then I would suggest just going with the browser route.
Lightning is an excellent browser (F-Droid) and has Google as a homepage already. (I recommend changing this if you are going to use the browser. You can save the Google page as a bookmark to use later.)
Simply touch the icon cluster on the Google homescreen to access the web versions of Google apps.
Hello i want to record my mobile screen video. I have already used many application. maximum video quality are not so good. I need a high quality mobile screen recorder. Suggest me.
You're welcome.I installed and configured the "Hacker's Keyboatd" as suggested, and now have the voice typing microphone on the keyboard, thank you.
I hear you. It's frustrating when you don't know what happened when something gets messed up.I just wish I understood what happened to the GBoard keyboard
it's not just wifi, but mobile data as well.......though that is always a great way to start troubleshooting wifi issues.Router / modem reboot ??? ...
