Installing Android onto persistent USB stick + Google Parent
Android X86 install and runs perfectly well on Dell Laptops, You can run it 'live' from a USB stick or DVD, to see how well it runs on your laptop. But, to install it you'll need to reboot and choose install from the Android boot menu. DO NOT attempt to partition the hard disk, as Android has it's own partitioning scheme that's very different to either Windows or Linux. I had better results using Lineage OS (also so on the Android X86 site)
The current version is based on Android 8.1, and there's a beta of Android 9. It really is full Android on a Laptop. Don't worry about a lack of touchscreen, the Laptop's touchpad works just fine.
lg k20 sd card question
ok i got a new samsung 32gb sd card and installed it. i will not set it to be extended now as i do not need to have it get encrypted and then if it somehow fails i can't do anything with it. so if it fails now maybe i can recover it. one good thing i guess is google back them up for me, that is one good thing but a bear to retrieve from google. thanks for the help
Google account backup vs Samsung account backup differences?
Can't really comment about Samsung or Google backup, as I don't use either.
But I'm thinking if you can go without a phone for 60 days, 2 months. Do you actually need a phone at all?
I have mentioned "If I lost my phone or if my phone is faulty for 60 days", I am preparing for worst case scenario. It is possible that I lose my phone and someone return it 60 days later and while searching for the phone I use an old spare phone S4 that I am unable to restore backup due android version too old. That guy in the example sold his phone and used an iphone for over 60 days and lost all backup when he wanted to use android phone again.
S10+ keeps randomly restarting, is there any way to find out what's causing it?
try putting the phone in safe mode and see if it is still happening. safe mode prevents 3rd party apps from running. it is just a troubleshooting tool. if it is still happening there, then i would for sure do a factory reset.
make sure you back things up using smart switch.
or as @mikedt suggested you can use smart switch to update your phone. you can't install firmware using smart switch, especially if your phone already has the latest update.
Need to put stock FW on Samsung Galaxy S5
Listen..if you really like those S5's..and you want to stick with it..I would give it a go ahead..
I staid with my S5 for while..on a 3g(keep in mind that's what the phone says you are getting) but at the same time I heard..understand..and experienced that is ACTUALLY greater than 3g speed you will get..
Mine was a sprint used on tmobile then in cricket..when I tested it I was getting about 4g speeds(in cricket..because tmobile is the worse)..
You can stay with it..
[APP][5.0+] Notification Timer ⏱️: View and use stopwatch timers right from the notification drawer!
In using the app, I realized I wanted to be able to have more timers displayed at a time, so I created a small timer layout to fit more into the notification. Here's the update with that feature- enjoy!
Download it here: Notification Timer (Stopwatch) ⏱️⏱️⏱️
Version 1.2.0:
  • Added small timer layout. With the small layout, up to twelve timers can be displayed at the same time and up to six can be displayed without having to recreate the notification after focusing on a timer. By default, the small layout will be used if five or more timers are active, but this can be changed in Settings.
  • Added setting to specify which layout focused timers should use.
Help Android 7.0 - IP and Proxy setting will not persist
I really don't know how we've veered this far OT, @svim! I'm very familiar with router settings, and have security I defy anyone to breach.
As the highest paid [non-owner] employee at two consecutive companies, my security was legendary.
And in 35 years of computing, I have yet to encounter one intrusion, one virus, one malware, one privacy breach, etc.
I don't know why stating that I assign static IP addresses to the computers on my network turned me into an ignorant imbecile...
USB wont charge/ (sometimes)
Stop trying to charge the phone with your PC.
That is a very slow charge, that can barely build a charge if the phone is on.
Try using a wall charger.
Look at the mAh of the charge rate in your battery settings while it is charging.
If your device does not have this option, then get an app that does show this information.
While looking at this mAh number, change out your cords, trying each one of them.
This will let you see which ones are good and which ones are not.
CpuFloat is an excellent ad-free app for this.
Ampere (has ads) is another app that works as well.
NOWA 5 PRO smartphone boot problem after factory reset
You don't really need to be. You've got a counterfeit phone, and a rather cheapo one as well. And these are often very poor quality. There's really nothing you can do with the thing, as there's usually no support information for fake products. And really only thing you can do is see about returning it for a refund.
If it had been a real Huawei nova 5 Pro, and not a cheap knock-off. It probably wouldn't have crapped out on you, and manufacturer support wouldn't have been a problem.
Hi,
Thanks for the info.
I did get a refund for it and they didn't ask for it to be returned. And didn't actually fail/crap-out as you put it.
I simply just did a factory reset, as I mucked about with too many settings without knowing what they were for. And it didn't have the 'Mount System' option in the list where the Format and ADB options are..
I just bought another cos it is a good phone and less than £50, regardless of it being a fake clone of Huawei Nova 5, and I'm gonna see if I can simply use ADB to pull drivers off the working nowa5 , and sideload into the other.
I'm a complete novice to Android and Linux OS's, and letting me know about it being Linux has helped loads. Thanks.
I'm autistic, and enjoy learning and fixing things. So I see this as a fun little project.🤪
Sunlich 👽
Android 10 update
This normally only happens when you have your phone on or near your wallet or purse as it picks up your contact less cards. If this is not the case and it is randomly happening try restarting your phone or switching NFC off in the menu shade. (Pull down from the top of the screen)
I searched and searched and finally found this lol...I do have a wallet pop case and my Santander card was causing the issue. Its kinda dumb as it never happened before the update. Thanks!!
Filter
