Android security/compromised phone help please.
- By MrJavi
- Ask a question
- 1 Replies
Maybe this will be of some help
https://www.multcloud.com/tutorials/stop-onedrive-from-syncing-1234.html
Microsoft cloud storage but have you considered downloading whats important to you and then deleting you account and uninstalling all Microsoft apps. Then change the rest of your passwords on your other accounts. Then you can choose a cload storage that provide 2 step verification and better security. If you have developer option enabled make sure usb debugging is turned off.
I would also recommend a factory reset but you will need your Google account password or youll be lock out of you android (FRP). I suggest writing the new password down on paper. It might be hard to remember the new recently changed password.
