Locate the package name, example voicemail.apk then use adb to uninstall it.I have an S7 Edge on Sprint. It has the stupid voicemail app installed. How can I get rid of it - it won't let me uninstall it? Or is there some way I can get the standard voicemail notification back - so when there is a a VM, I can pull down the status bar and just dial into my voicemail? I could live with the app if it didn't have the stupid ads. But I'd really prefer to get rid of it.
I've seen some posts around that say you can go into your sprint account and remove visual voicemail from your account features, but I don't have that option anywhere.
From what you're describing, seems like you might want to look into AlarmManager:
https://developer.android.com/training/scheduling/alarms.html
https://blog.teamtreehouse.com/scheduling-time-sensitive-tasks-in-android-with-alarmmanager
package com.tomtom.jsonreader;
import android.os.AsyncTask;
import android.os.Bundle;
import androidx.appcompat.app.AppCompatActivity;
import android.util.Log;
import android.widget.ListAdapter;
import android.widget.ListView;
import android.widget.SimpleAdapter;
import android.widget.Toast;
import org.json.JSONArray;
import org.json.JSONException;
import org.json.JSONObject;
import java.util.ArrayList;
import java.util.HashMap;
public class MainActivity extends AppCompatActivity {
private String TAG = MainActivity.class.getSimpleName();
private ListView lv;
ArrayList<HashMap<String, String>> contactList;
@Override
setContentView(R.layout.activity_main);
contactList = new ArrayList<>();
lv = (ListView) findViewById(R.id.list);
new GetContacts().execute();
private class GetContacts extends AsyncTask<Void, Void, Void> {
@Override
protected void onPreExecute() {
super.onPreExecute();
Toast.makeText(MainActivity.this,"Json Data is downloading",Toast.LENGTH_LONG).show();
@Override
protected Void doInBackground(Void... arg0) {
HttpHandler sh = new HttpHandler();
// Making a request to url and getting response
// String url = "http://10.0.2.2/mydocs/test_data.json";
// String url = "https://api.myjson.com/bins/xalc8";
String url = "http://api.androidhive.info/contacts/";
//String url = "https://teamtreehouse.com/matthew.json";
// String url = "http://api.openweathermap.org/data/2.5/weather?q=cape%20town&units=metric&appid=f8d99ec86985a645328e23aad42c07d8/";
String jsonStr = sh.makeServiceCall(url);
Log.e(TAG, "Response from url: " + jsonStr);
if (jsonStr != null) {
try {
JSONObject jsonObj = new JSONObject(jsonStr);
// Getting JSON Array node
JSONArray contacts = jsonObj.getJSONArray("contacts");
// looping through All Contacts
for (int i = 0; i < contacts.length(); i++) {
JSONObject c = contacts.getJSONObject(i);
String id = c.getString("id");
String name = c.getString("name");
String email = c.getString("email");
String address = c.getString("address");
String gender = c.getString("gender");
// Phone node is JSON Object
JSONObject phone = c.getJSONObject("phone");
String mobile = phone.getString("mobile");
String home = phone.getString("home");
String office = phone.getString("office");
// tmp hash map for single contact
HashMap<String, String> contact = new HashMap<>();
// adding each child node to HashMap key => value
contact.put("id", id);
contact.put("name", name);
contact.put("email", email);
contact.put("mobile", mobile);
// adding contact to contact list
contactList.add(contact);
} catch (final JSONException e) {
Log.e(TAG, "Json parsing error: " + e.getMessage());
runOnUiThread(new Runnable() {
@Override
public void run() {
Toast.makeText(getApplicationContext(),
"Json parsing error: " + e.getMessage(),
} else {
Log.e(TAG, "Couldn't get json from server.");
@Override
public void run() {
"Couldn't get json from server. Check LogCat for possible errors!",
return null;
@Override
protected void onPostExecute(Void result) {
super.onPostExecute(result);
ListAdapter adapter = new SimpleAdapter(MainActivity.this, contactList,
R.layout.list_item, new String[]{ "email","mobile"},
new int[]{R.id.email, R.id.mobile});
lv.setAdapter(adapter);
import java.io.BufferedInputStream;
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStream;
import java.io.InputStreamReader;
import java.net.HttpURLConnection;
import java.net.MalformedURLException;
import java.net.ProtocolException;
import java.net.URL;
public class HttpHandler {
private static final String TAG = HttpHandler.class.getSimpleName();
public HttpHandler() {
public String makeServiceCall(String reqUrl) {
String response = null;
try {
URL url = new URL(reqUrl);
HttpURLConnection conn = (HttpURLConnection) url.openConnection();
conn.setRequestMethod("GET");
// read the response
InputStream in = new BufferedInputStream(conn.getInputStream());
response = convertStreamToString(in);
} catch (MalformedURLException e) {
Log.e(TAG, "MalformedURLException: " + e.getMessage());
} catch (ProtocolException e) {
Log.e(TAG, "ProtocolException: " + e.getMessage());
} catch (IOException e) {
Log.e(TAG, "IOException: " + e.getMessage());
} catch (Exception e) {
Log.e(TAG, "Exception: " + e.getMessage());
return response;
private String convertStreamToString(InputStream is) {
BufferedReader reader = new BufferedReader(new InputStreamReader(is));
StringBuilder sb = new StringBuilder();
String line;
try {
while ((line = reader.readLine()) != null) {
sb.append(line).append('\n');
e.printStackTrace();
} finally {
try {
is.close();
return sb.toString();
King root doesn't root the S8 +. You should back up anything important to you and reflash the correct firmware.How can I go about finding out exactly which app or apps are causing my phone to freeze in the middle of, close out my texting window, and pretty much any other window I have open at the time. Even when I am recording a video or creating my next beat....it will lag and/or completely close out. I went about using the king root to root by phone, but I'm not sure if I didn't do it correctly and maybe that's causing the issues??
"?"-droid...too much noise and not enough info. I was taught to never install anything NOT from Play Store. So, where does one get educated on all things NOT GPS? Does this stuff work with non-rooted phones? No nag screens from not going thru GPS?
Russ
