How will the Samsung Galaxy S11 Plus be different from the Samsung Galaxy S11?
- By mikedt
- Smartphones
- 1 Replies
One will be slightly larger than the other.
Indeed! Android Development board.Your question should be moved to the applications development section.
what phone do you have? has frp been tripped?How can I remove it
I'm not sure right now. I know that Sprint Backup on my Galaxy 8+ has a similar icon to what you've mentioned (MacOS "time machine") but this phone is under Verizon. Thanks a lot. This was a really helpful post.Backup utility was my thought, mainly because it looks like a knock-off of the MacOS "time machine" backup utility's icon.
Do you have any apps that can do scheduled backups?
Just below my phone number in Phone Status is "MIN" with a phone number for my area code. Anyone know what this is?
Right, thanks.
Unfortunately I didn't read your clear instructions properly!
I have now signed out through My Files>Settings, and so far it seems to have worked.
Thanks for your help.
I know. And it sucks!A fact any pet owner (well dogs and cats, parrots can live for 70+ years) has to accept is that their loyal companions life will be much shorter than our own.
I'm sure there are some tools that can do that, but I have no idea what they are.Is there a way of checking the battery strength?
