Seriously, the older I get the less comfort zone I try to hide in. I've reached a point where I'm not intimidated, afraid of failure, embarrassed, etc. Those are the things that I consider my comfort zone. As an old man, nobody expects a lot from me, and I can easily surpass that. Just don't ask me to do any public speaking. I suffer greatly from dyslexia and affluent speech I was not gifted with. I used to hide that fact in my comfort zone. Nowadays I just laugh at myself and go on down the road.Yes, it is possible to screen mirror your phone and have it full screen. However, the ability to do so may depend on the specific phone model and the mirroring app you use.
If the screen2auto app you mentioned is not displaying the full screen on your car's infotainment system, you can try using other screen mirroring apps.
Additionally, some custom ROMs or rooting methods may provide more control over screen mirroring, but keep in mind that rooting may void your phone's warranty and can have security risks.
Can anyone help scan wechat, pleasehere is my new qr code. Thank you very much <3
I was going to mark your reply as BEST ANSWER but... anyway, that did the trick! Thank you!click on your avatar, far right corner>select account details>scroll down to devices>you should be able to edit from there.
Yes you're right, and Thanks ocnbrzeok i alerted the mods to move this to our development forum. i am no developer so i can't help with your inquiry. but to be sure you want to develop an app that is similar to a document scanner.....correct?
no that is the name of the phone. the model number should be like SM-A115U1
Assuming your Galaxy S18 reference is just a typo, if you're actually thinking of something like a Galaxy S8 that is a better option than your daily usage Z Fold. I'd suggest you avoid one of those one-button rooting apps like Kingo and instead opt for a process like TWRP/Magisk:
It's only a bit more involved but results in a cleaner, less obtrusive quasi-root. Since you're apparently willing to educate yourself on the rooting process, getting comfortable using the Odin utility will give you better sense about your phone's internal functionality.![]()
Samsung S8/S8+ TWRP & Root / Magisk Guide - SM-G955F Tested [2022]
XDA has helped me with many previous projects, its about time I gave back to this community. I have been trying to fix my Samsung S8+ which took 3 to 4 guides from this forum and combining into one. From what I can tell, pre-2019 was a lot...forum.xda-developers.com
You might also want to be sure you download and save the appropriate Samsung stock ROM for that particular model of S8 (or for whichever phone you intend to buy for this project). Just in case a problem occurs while rooting the phone or later after you do root it, having a stock ROM on hand allows you to flash the stock ROM to restore the phone into fully functional condition again. (.... and then root it again to start over).
It doesn't but if I am going to bother to order a dedicated camera device, I might as well get the flexibility of other kinds of time lapse, some of which might require better quality cameras.Why is camera quality important just for seeing where the sun hits at different times of day/year?
'new folder/new folder (2)/pictures' on her laptop.
