Help Emulator "Application Stopped" Error
Hi, I have a problem with the android emulator. When I enter any game, I get an error like "Unfortunately, XXX has stopped". I have tried many different versions of the emulator, but the problem is the same. I don't know what to do, can you help me?
I think there is no problem during installation. I tried looking at different videos from the internet. But I couldn't find the solution.
I've tried: Android-x86 [Pie (9), Oreo (8), Nougat (7)], Remix OS, Phoenix OS
My Computer Features:
Processor: i5-3210M
RAM: 4 GB
Graphics Card: AMD Radeon™ HD 7670M
HDD: 500 GB
The GB I allocate to the emulator: I've tried 200GB, 50GB and 32GB .
Latest APK download causes phone to revert to earlier version app
On more than one phone that has a version (v1.06) already installed from an APK, when I navigate to the latest (v1.07) APK stored on our intranet, download and install it, the installed version on the phone then reflects an even earlier version v1.04.
The only way I can get the latest version onto these phones is to plug one of these phones into the Android Studio loaded PC, and run it as an emulator. Once loaded, I then use ShareIt to get it onto the other phones.
The latest APK is DEFINITELY v1.07 that is stored on our intranet, because phones that don't yet have it on, they reflect this v1.07 when downloading and installing it.
On the phones that are reverting to an earlier version, I have tried uninstalling the app first, deleting any previous APK and file downloads, and then downloading the v1.07 version. It still reverts back to v1.04.
i have a question about the ding tone application
Agree with chanchan05, why get so nervous? This is quite normal that apps ask your permission first and then allow you to access people in your contact lists. This is quite normal in many apps. If you don't want it to access your contact list, you can simply deny it. I have been using Dingtone for quite a long time, I got a US phone number before I go on a short-term trip to Italy, this app helps a lot. So if you want a 2nd number for international calls and texts but don't want a carrier, this app is definitely the best choice. The international calls have a cost, but much cheaper than regular phone calls. But if you have credits, then the calls are free indeed. Dingtone-to-Dingtone calls are totally free over wifi or cell data. I and my family and friends always talk and text on this app, it works great. btw, it also works on iPad as long as you installed this app on it. I love this app and I will recommend it to others if they need something like these.
Looking for a durable phone
Hey, I've been tasked with picking a durable and 'rugged' phone for a relative. Budget is 320 USD, we're looking at European market.
So far I've looked over Doogee S55 and S60 and Blackview BV9000 pro.
Can't decide which of those three, or something completely different?
I think not having a USB-C is not cool these days, which is my primary concern with the S60.
Apparently, a 3.5mm Jack is mandatory (no matter how much I try to explain the opposite to the buyer)
All help is appreciated. 😉
Hi...
I have recently got myself a NOWA5PRO , duplicating masses of specs of the NOVA5PRO. 8GB RAM 128GB INTERNAL UPGRADEABLE TO 255GB add another 128tf card , and separate 2 SIM slots. 10-core processor, 13mp / 18mp front/rear cams.
Only problems ihad was resetting to factory by wiping cache and data. As long as you safeguard against , possibly geabibf it's drivers and backup. Or don't do a reset as I did.
Only cost around 50gb' pounds. I have 2 now and very nice though still to fix 1st I bought from China. .really inexpensive but not much support for this unbranded - Huawei NOVA5PRO almost duplicated.
Wish.com or eBay. Search; NOVA 5 PRO''
Sunlich
Sunlich 👽
User Acquisition Report Problem
Hi!
I recently encountered a problem in Play Console. When I go to my "User acquisition" -> "Acquisition reports" of my game, At "RETAINED INSTALLERS" tab, "Play Store (organic)" of "FOR 1 DAY", "FOR 7 DAYS", ... are EXACTLY ZERO!, even though "First-time installers" shows normal numbers.
They used to be good numbers but all of them are ZERO now.
I attached screenshot of my console (that is user acquisition of Sep 2 - Sep 8) to show the problems clearly.
Do you guys have the same problem (is it maybe a Play Console bug) or is it just me?
If possible for you, please check your own Play Console profile and tell me that you have the same problem or not?
Apps Creating Maps app release version
I have a Maps app, which is working fine in debug mode. I've followed the steps https://developers.google.com/maps/documentation/android-sdk/get-api-key to set up the project, and create the API key - the map displays as intended.
When it comes to creating the release build, I'm having no luck. Again, I've followed all the steps to get the SHA1 of my keystore, restrict the API key etc - but when I create a release build and test it, the Map doesn't display.
I've tried so many things, so may combinations of keys and restrictions, I must be missing something obvious. So if anyone can suggest anything I may be doing wrong, please do!
The only specific question I have is: Should I be using the same API key for both debug and release, or should I create one key for each version? (I've tried it both ways, and neither are working for me).
Sim Card Hot Swapping Android
I've done quite bit of SIM hot-swapping on various phones, Huawei, Oppo and Samsung devices. Where I just eject the SIM holder and swap out SIMs, without turning the phone off, and the phones have always recognised the changed SIMs and connected to their respective networks. And any apps I use haven't had a problem with that, although my banking app can't authorise with a SIM change, because of the change of phone number.
I don't know the Zentality 720-c, but I guess it shouldn't be a problem with hot-swapping SIMs, unless the manufacturer has stated otherwise?
Filter
