getAssets().openFd() throw exception
- By ottersss
- Android Development
- 5 Replies
It's a good idea but unfortunately i need place that files in assets folder cause i using "play asset delivery" feature
Hadron, Thank you -- that was quick.It may depend on what phone you have (which manufacturer and what software version), but I'd start by opening my contacts app and looking for "manage contacts" in your settings. If you are lucky you may find something obvious like "move contacts" in there (my Samsung, running Android 13, has that).
(Back when this thread started it was often simplest to export the contacts to a vcard file and then re-import them to a different location, but things have come on a bit since then!)
thanks man, i'm trying to flash the rom on the ´hone but its failing in the end, i tried the first link you comented , now i'm trying to flash a newer version of android 10if you can get to fastboot then try this:
Motorola One XT1941-3 Stock ROM Firmware (Flash File)
Download the official Motorola One XT1941-3 Stock Firmware (Flash File) for your Motorola Smartphone. We also provide all other Motorola Stock Firmware.motostockrom.com
try the first one available and then scroll down to find instructions.
From my usage, I would say... one phone and one tablet.I like the idea and I would try one if the pricing was better. It's basically the price of two phones, but what you are actually getting is one phone with an extra screen.
