Help Update away! Not yet, but on a fresh Galaxy 11 later
- By ocnbrze
- Ask a question
- 7 Replies
no that is the name of the phone. the model number should be like SM-A115U1
Assuming your Galaxy S18 reference is just a typo, if you're actually thinking of something like a Galaxy S8 that is a better option than your daily usage Z Fold. I'd suggest you avoid one of those one-button rooting apps like Kingo and instead opt for a process like TWRP/Magisk:
It's only a bit more involved but results in a cleaner, less obtrusive quasi-root. Since you're apparently willing to educate yourself on the rooting process, getting comfortable using the Odin utility will give you better sense about your phone's internal functionality.![]()
Samsung S8/S8+ TWRP & Root / Magisk Guide - SM-G955F Tested [2022]
XDA has helped me with many previous projects, its about time I gave back to this community. I have been trying to fix my Samsung S8+ which took 3 to 4 guides from this forum and combining into one. From what I can tell, pre-2019 was a lot...forum.xda-developers.com
You might also want to be sure you download and save the appropriate Samsung stock ROM for that particular model of S8 (or for whichever phone you intend to buy for this project). Just in case a problem occurs while rooting the phone or later after you do root it, having a stock ROM on hand allows you to flash the stock ROM to restore the phone into fully functional condition again. (.... and then root it again to start over).
It doesn't but if I am going to bother to order a dedicated camera device, I might as well get the flexibility of other kinds of time lapse, some of which might require better quality cameras.Why is camera quality important just for seeing where the sun hits at different times of day/year?
'new folder/new folder (2)/pictures' on her laptop.
Hadron, Thank you -- that was quick.It may depend on what phone you have (which manufacturer and what software version), but I'd start by opening my contacts app and looking for "manage contacts" in your settings. If you are lucky you may find something obvious like "move contacts" in there (my Samsung, running Android 13, has that).
(Back when this thread started it was often simplest to export the contacts to a vcard file and then re-import them to a different location, but things have come on a bit since then!)
