Endless Background Service In Android Ore or More
If you don't mind do you have an example code or some thing like that for that work instead documentation.
It will be a big help.
I wrote a tutorial that demonstrates how I use a JobIntentService with fully working example project and code here:
https://techstop.github.io/android-broadcastreceiver/
Now here's the thing, there are different ways to use this service, so the example a linked above may not be what you're looking for. If not do a google search for "how to use jobintentservice" and plenty of tutorials will come up.
Help Had Google Acct, New Gmail Acct, now ALL Contacts & Calendar GONE
I had that same issue about three months ago..my contacts which I've saved for years and years in my Google where gone..I was deleting some duplicates..that's how it happened..the only reason I was able to get most of them back was because some how and I have not idea when but magically my contacts also existed in my Samsung account that I don't remember setting one up..but well..bottom line..it's good to have back ups...
Help Any way to block a specific phone number "Format"
since a couple days I keep receiving phone call from numbers that, I think, comes from Europe. Is there any way to block that phone number format? (obviously im from North America, and want to let number XXX-XXX-XXXX in)
FYI Saudi Arabia, Congo, and Central African Republic, are not in Europe.
You might be able to get your carrier to just block international incoming calls, if you're not expecting thrm, and not have to do anything with your phone.
Samsung Galaxy Ethernet interface needed
Saw a post from Jeam in 2016 where I'm thinking "Did I post this?"
"...it seems to be impossible to download the updates that way, it keeps asking to do it via WiFi.​
The problem is that the wife is extremely concerned about possible long-term health issues related to wireless signals, and I would like to keep the peace by doing the updates either by mobile data or by Ethernet..."
Our home became WiFi-free earlier this year and during our final remodel (of 3) we had Ethernet pulled to every room. She uses Apple and has been hooked up since June. I still haven't found out how to connect my Samsung Galaxy 7 (Device name: Samsung-SM-G930A).
ANYONE KNOW how to enable Ethernet as the signal source? And what hardware (dongle) is needed?
Thank you,
Grady
You do know that mobile data also uses wireless signals?
But anyway, Amazon lists USB Ethernet adapters that are apparently Android compatible.
https://www.amazon.com/android-usb-.../s?k=android+usb+ethernet+adapter&rh=n:172282
Can't recommend any particular one though, as it's not something I've considered using myself.
Apps Webview app image upload not working
The question here looks almost exactly like what you're describing
https://stackoverflow.com/questions/5907369/file-upload-in-webview
"However, in the android 3.0 emulator / AVD, when I click on "Choose file", nothing happens, no file dialog is opened!!!"
Seems to be a few answers, depending on your version. Looks like you need to add support for the file selector in your Android code.
In the end I had a look around the internet and found a chap called Zid who's good with android, I emailed him, told him my problem, he asked for .text copies of my MainActivity and Manifest, then he emailed me altered versions and boom it worked!
save both normal and HDR photo
Hi all
I need to save both normal( i mean SDR exactly) photo and its corresponding HDR photo.
iphone mobiles have this kind of ability that u can save both normal and HDR photo of a scene.
there are applications that save 3 SDR photos and those corresponding HDR. I do not need this. I just want 1 normal photo and its corresponding HDR photo.
please, any one who can help me with any kind of idea, I would be gratefull.
Improper export of android application components
Another thing I should mention. This is an old vulnerability and google has since beefed up code obfuscation. Keep in mind that to exploit this vulnerability you need to know the exact class name which would be obfuscated.
Reporting an app with exported activities will undoubtedly do nothing since this is allowed by google. Google may just link you to the documentation at best.
Filter
