Communication between 'administrator' and 'user' devices
I'm going to apologizes in advance for all the inaccuracies in what I am about to ask.
I'm a mechanical engineering student working on a project that has turned into some app development the only coding I know is a bit of MatLab- I am in way over my head.
I need to build something that will allow a course instructor to dictate the display of a students device 'user device' from their own device 'administrator device' . The bones of this project would be a set of buttons on the administrator device, and each one when selected would cause a figure to be displayed on the user device. It seems like a bluetooth output from the administrator device and and bluetooth input to the user device would be the right way to go, but I don't actually know if that's possible or what other other options would be...​
Any ideas, suggestions, or recommendations would be incredibly helpful
Help Three down (2 to go?)
  • 3
  • 5 Replies
But I guess it's a regular issue that needs widespread awareness if people worldwide or trying to contact someone on a down network / carrier via phone or data and don't know why they cannot.
Seems to be on the mend according to reports.
and I'm now back on 4G at 12:05 so 12.5 hours out for me.
About Huawei Mate 30 Pro
I am sure that P20 can work fine with Google Play because it has stock Google Service Framework. In fact, I have helped so many P20 users to get their P20 working well with Google Play.
The only question is that Huawei's own app store made all Google apps unavailable in September this year. Then the launch icon of Google Play Store disappeared from your P20 home screen. But this is not a problem at all for us. :D
This was in a local Huawei showroom back in May, I'm friends with the staff there. I tried to install Play from AppGallery on a demo P20 they had, and it just crashed. I didn't do any further investigation, that was about the time I thought about having a Samsung instead. No Huaweis in China have the Google Play icon on their EMUI launcher.
I see that in the AppGallery on my own Mate 10, that all Google apps have now been removed, and that was where I installed Play from in the first place. But it's still on my phone, and is still working with a VPN.
After conversion to 64 bit for AR App using Unity & Vuforia the Camera does not work
We have an autmented reality app developed using UNITY and Vuforia. It is on Play Store and it works fine.
But after we converted it to 64-bit architecture, the camera functionality does not work. We get white screen and we are unable to scan business card using vuforia and camera doesn't works in other places too like qr code scanning etc. It works in 32 bit architecture. What could be the reason for camera failure in case of 64 bit architecture. How to resolve this issue?
root lg k11+ HELP!!
so after looking into the link, please keep in mind that the actual source was from an xda guide that was published in 2015. so i do not know how effective the process will be. here is the original thread:https://forum.xda-developers.com/android/development/guide-root-method-lg-devices-t3049772
always look to xda for anything root related. it is a developers forum where they post their guides, roms, kernels and recoveries. always do your research there first. your problem is that there is no forum for your device in xda. this means that there is no development community supporting your device. just remember no dev=no fun.
if it was me as soon as i know that there is no dev community to help root the device, i would stop my research right there. the really is no reason to look further. each device has a specific process to gain root. not all device can use the same exploit to root the device as in the days of old. manufacturers and carriers have tighten their grips on the phones they offer.
the main reason i would stop if there are no dev support, is because that means there is no custom recovery. a custom recovery allows you to make a nandroid backup which is like a save point in a video game. if you mess up, you can always restore your backup and it will be like nothing happened. to just root the phone so that you can get rid of bloatware and such is a big risk without a custom recovery. bloatware are apps carriers and manufacturers added to the phone. they are considered system apps. a lot of system apps are tied together so
that if you delete one, you might break another app and possibly soft brick your phone. without a custom recovery, the only thing you can do is flash a firmware update which most likely will unroot your phone.
so i do not think that you will be able to gain root on your device at the moment. you can try the guide @Dannydet linked, but i'm doubtful it will work....but you never know. i highly recommend that you stop looking for a root process for your phone. at least not until there is a custom recovery for your phone.
good luck and keep us posted.
Unroot/Flash stock firmware Galaxy S8
Choose the most recently dated one (2017-08-13), it will allegedly have the most updates. Well at least up until the stated date of the ROM, there 'could' be more OTA updates to come of course once you flash the phone but that's conditional.
Looking at your initial posting, if the current install is just rooted but running a stock Nougat, in the SuperSU app's Settings menu should be a 'Full unroot' option. If it works it should do just that. I've read it works most of the time but that's also dependent a lot on how much other customization to the base OS the user did while rooted. Worth trying and if it doesn't work out you were planning on flashing the phone anyway.
Help Antisocial phone on wifi: talks only to my router, not other devices?
MoodyBlues: It's solved now (dumb quirky router), but I'm nonetheless taking you up on your recommendation and installing a terminal emulator! :)
Excellent! It'll come in handy many times.
(BTW, I've only interacted briefly on this forum, but thanks for being so nice and helpful! :) )
You're very welcome. I hope you hang around!
My note 10+ keeps telling me to check my connection/cable to see if it connected properly but it is
My note 10+ is having a issue when I connect it to my PC, this hasn't ever happened to me before and im getting fustrated to why I cannot simply just connect my phone to my PC and it worked before the cable is fine it shouldn't have any problems and my PC is working just fine so what can I do?
You are far from alone. ALL my devices had that occur. Note 10 too. Switched to braided cable and a month later, same thing. The port on device is money hungry for perfect cables. NO my port is not defective.
did you buy a new cable yet?
LG V30 Long press to move app no longer working after system update
Sounds like the system update changed the way your homescreen is arranged.
You can always install a different launcher from the play store, such as Nova launcher that can do as you wish
FIXED IT! THANKS!
its so weird, not sure what happened. but I downloaded Nova launcher didn't do anything to it i just installed it and go on with my day. later when i opened my phone everything was back to normal. I can long press and move apps now.
I tried to uninstall Nova to see if it was that that did the trick. nothing changed. long press and widget works like normal. weird...
Thanks for the help!!
Filter
