Pixel 2 XL Issues
Solved issue with PlayStation Vue. It is an app problem related to some PS Vue restrictions about being out of home area for greater than 30 days. After trying several VPN apps, I was able to trick PS Vue into thinking we were back in home area and it started working. It would be nice if developers displayed some kind of warning/error message.
Phone also seems to be getting better battery life on Android 10.
How to recover deleted videos if not saved on cloud
I deleted them from the gallery of the device Samsung galaxy a 20
Okay, thanks. I have no experience with Samsungs, but don't they offer their own cloud storage? If so, are you sure your files weren't backed up there?
I know you said they weren't in the cloud, but let's just run down a few things you may not be thinking about. Besides Google Photos with its option to auto-upload, do you have any other accounts, such as Dropbox or Amazon, that may have saved them?
Have you checked your gallery app for a trashcan? Some apps offer options as to what happens when you 'delete' a file, such as putting it in a holding place for X days before actually deleting it. The trashcan may be obvious, like in the app, or it may be buried somewhere in the file system.
First check the app to see if there's a trashcan within it, and check it for files. If that fails, then move on to perusing your file system using a file manager. You're looking for anything Samsung-related, then if that fails check other directories. You're basically just looking for anything that may hold those deleted files.
Post back and let us know your results.
Help Moto G5s wont start after battery gone flat
If your Moto G5s goes flat there isn't enough charge to boot phone. The phone will boot then shut down & you cant charge it.
To fix
1 Plug in USB charger
2 Hold Vol- ( lower volume button) & power button for 10 seconds or so
3 Now you should boot into Command prompt recover mode. ( see pic of Android bot with his panel open & text beneath him,
4 Look at text. Look for line that states Battery ok (charging) if this is green then phone is charging.
5 Wait 30 minutes or so, you should by now have at-least 10% charge in phone. ( wont show until you start phone)
6 select with volume control buttons option on right near buttons for power & volume, the option Start.
Now phone should boot.
7 leave on charger until phone charged
Message from the developers
Hi,
We created this forum to get unique views from you.
Trick Colors 2 is a casual puzzle game developed by Rodio studios (just two people).
Our friends who have tried out the game really liked it(but....). So can you check the game out and give your thoughts on it ?
We would appreciate it if you can.
Thanks a lot.
Here's the link to the game
https://play.google.com/store/apps/details?id=com.trickcolors2.rodio
Here's the link to the trailer
Root Format Write-protected Encrypred SD card
Svim - Sure I will try to get a warranty replacement.
When I try to format on Android Phone - I am getting this error: command '13 volume partition disk:179,64 private failed with '400 13 command failed. 13 keeps changing to a different number.
Does Gparted let you create a new partition table? That will wipe everything, but I don't know if it works with write protection on.
Or in Windows
1. Open a command prompt then type:
DISKPART
2. To find the disk number of the SD card type:
LIST DISK
3. Select your SD card, if it's disk #3 type:
SELECT DISK 3
4. To clear read only type:
ATTR DIS CLEAR READONLY
Kate - I will try and reply.
Repurpose Straight Talk Phone?
Yep Yep, all correct.
$40 tablet for the kids running Oreo ;) Runs Real Racing 3 beautifully. Qualcomm/Snapdragon, quad core, 2GB mem, 16GB built in and you can add 32GB SDCard.
Pulled the sim before installing the battery then went through it disabling all the crapware and installed an app locker.
Note: Deny permissions to "Wi-Fi Utility" over and over until you get the "remember this decision" options. It's a data collection app that uses wi-fi, cell, and Bluetooth to constantly attempt connecting to anything and everything in range then sends that data back to whoever.
Jetaudio problem with GPS
Hello,
I have the jetaudio + 9.9.0 for android on my Samsung s8 which give entire satisfaction except 1 thing
I start the music and that's work very fine but when i start a gps program at the same time with sound like ( google map, waze , tom tom , mazda gps car ) i have the sound also but when the message is finished the sound does not come back to the jetaudio player
I cannot have the 2 sound together working ( 1 after the other )
Is this something that we can solve in the settings (so many settings ) ,am i the only one, a known bug ?
Many thanks for your help
Am I hacked?
There is a Samsung system app called "bootagent", so as you have a Samsung phone that doesn't sounds like anything to panic over.
You'll need to tell us more about the bluetooth apps for anyone to make a judgement there.
You never get calls? That might be a sign of a problem, but not necessarily with the phone (network coverage, not hearing the ringer, or certain junk calls deliberately disconnect immediately in the hope you'll phone them back).
The bottom line is that we need more information in order to help, but it's not clear from what you've posted whether you really have a problem. And being "hacked" is actually a very low probability event, so it's best to consider other explanations first.
Oneplus 6T to Oneplus 7T
Guys, planning to buy the 7T or 7T Pro. What are your thoughts???? and is there an OP7T Pro in the first place?
Until the official announcements begin on the 7T series in about a week's time on the 26th September for the standard model and the 10th October for the 7T Pro, it is still speculation as to spec's, prices and which countries will receive which 7T models and when. See...
OnePlus 7T and 7T Pro: Release date, specs, rumours, news and features
OnePlus 7T Pro render shows familiar design with a new camera sensor
This is the 7T bad boy that interests me... the McLaren edition...
OnePlus 7T Pro renders leak, including McLaren edition
Whatsapp phishing attempt
This morning I've had two texts allegedly from Whatsapp with a code for 2 factor authentication. The first was from a UK mobile (cell) number, and the second had a Whatsapp logo displayed by the text message. Naturally I deleted both of them as I don't use Whatsapp, and it's not installed on my phone.
I also had a voice calll saying '"Your Authorization code is 999999" with no clue what it was referring to. I blocked the number.
As 2FA is coming to UK banks and other online transactions soon, be aware of these ,maybe not so obvious, scam calls and texts.
This one's a doozy!
Ocnbrze, I did as you advised. Put my phone in safe mode, and it's still happening. I'm going to clear data but have a question. If I clear all data and cache, won't this make me lose all my bookmarks? And if so, would it be better to delete the app and re-install? I can't believe I'm the only one who has had this problem. Thanks for.your help thus far.
if you have your bookmarks in chrome then you are all good. those are saved not sure about other browsers however.
Poblano VLE5
I use this phone for calls only. Everytime I'm on it for a couple of minutes it disconnects. I couldn't figure out why but then I finally did and it goes to airplane mode. Why? I called my bank and had to put my card number in and Everytime I looked at my card when I went to type the numbers it went to a screen I called from. Basically I had to go back tap the phone number wait for the dial screen to enter. It disconnected and guess why. Airplane mode. This is a bunch of crap
Filter
