Until the official announcements begin on the 7T series in about a week's time on the 26th September for the standard model and the 10th October for the 7T Pro, it is still speculation as to spec's, prices and which countries will receive which 7T models and when. See...Guys, planning to buy the 7T or 7T Pro. What are your thoughts???? and is there an OP7T Pro in the first place?
if you have your bookmarks in chrome then you are all good. those are saved not sure about other browsers however.Ocnbrze, I did as you advised. Put my phone in safe mode, and it's still happening. I'm going to clear data but have a question. If I clear all data and cache, won't this make me lose all my bookmarks? And if so, would it be better to delete the app and re-install? I can't believe I'm the only one who has had this problem. Thanks for.your help thus far.
tbh next time if you want to root your device, pick a device that can be rooted. looks like huawei has decided to lock the bootloader and devs are having a hard time unlocking it. i guess in the past huawei used to give out a unlock code, but not any more.Hello everyone!
I need to root my Nova 3 because I can't satisfy my default device. I want to customize my device as my wish but I don't know anything about android rooting. So can anyone tell me is that safe to root my device and is it legal to root an Android device?
Camera does not work on this rom.Hi, I need help with the camera, not found, I try with magisk root but no found
Did you EVER get an answer to your original question? I read and understood it, and am looking for the same info.
I don't use Gboard, and I don't use voice commands, but I find this absolutely ridiculous! Incredible, really.Nope, never did. You have to let the phone teach you![]()
Thanks for the info. I have zero experience with Samsung, so when the OP called it "samsung audio player," I took that as the name of an app, a built-in Samsung app.So I was just clearing up what the actual app was.
https://github.com/androidtrackers/certified-android-devices.git 530 something commits in there, you should be able to find commits and changelogs for your phoneNo, it varies by maker and version. It will come down to trading one or the other for added performance or features. Checkout github for your device and find the packages apps and settings platform and click on commits, as you scroll you will see where these things are switched back and forth or changed becuase it did not work the way the DEV intended. Hope that helps
