Samsung Galaxy Note Pro 12.2 keyboard problem
- By jeafra10
- Smartphones
- 0 Replies
My keyboard will not come down and let me type anything I've reset it I've turned it on and off I've set the volume in the power for 8 seconds nothing seems to work
//java client
OutputStream output = client.getOutputStream();
DataOutputStream out = new DataOutputStream(new BufferedOutputStream(output));
byte[] msg;
if(strings[1].equals("swipe"))
out.write(strings[1].getBytes());
out.flush();
//strings[0] contains the movement information in format of:
//xmovement_ymovement
//for example: 2.5365_8.5478
msg = strings[0].getBytes();
out.write(msg);
out.flush();
#python server
#the 1024 is a temporary number I just put in there
#because I don't know how to find the size of the data in the java client side
request_byte = client_socket.recv(1024)
print("reqeust_byte size: " + str(sys.getsizeof(request_byte)))
request = request_byte.decode()
print("Received " + request)
if request == "swipe":
movement_byte = client_socket.recv(1024)
print("movement_byte size: " + str(sys.getsizeof(movement_byte)))
movement_str = movement_byte.decode()
x_movement, y_movement = movement_str.split("_")
print("x: " + x_movement)
print("y: " + y_movement)
swipe(float(x_movement), float(y_movement))
Sorry for the delayed response and thank you very much. Using your suggestion solved that problem. I think I just need to sit down with someone who also has an android who can walk me through the learning process. Again, thanks so much!!the best way to send videos, especially large sized videos thru text or email is to use google drive. just upload the video there and use the share option. you should be shown a link which you can just copy and paste in to either text or email. i know it is not quite the same, but texting especially is not that sophisticated when it comes to handling media files like that.
http://wikiahow.com/how-to-send-large-videos-through-text-on-android-with-pictures/
@Override
protected void onPostExecute(String result) {
ArrayAdapter<String> adapter = new ArrayAdapter<String>(getActivity(),R.layout.spinner_layout, trainers);
spinner.setAdapter(adapter);
adapter = new ArrayAdapter<String> (getContext(), android.R.layout.simple_spinner_dropdown_item, trainers);
<?xml version="1.0" encoding="utf-8"?>
<TextView xmlns:android="http://schemas.android.com/apk/res/android"
android:id="@android:id/text1"
android:layout_height="wrap_content"
android:textAppearance="?android:attr/textAppearanceListItemSmall"
android:gravity="center_vertical"
android:paddingStart="?android:attr/listPreferredItemPaddingStart"
android:paddingEnd="?android:attr/listPreferredItemPaddingEnd"
android:minHeight="?android:attr/listPreferredItemHeightSmall"
android:paddingLeft="?android:attr/listPreferredItemPaddingLeft"
android:background="@color/logoGreen"
android:paddingRight="?android:attr/listPreferredItemPaddingRight" />
Thank you so much for telling us!This game is awesome!![]()
sorry i'm not sure i understand what it is you are asking. are you having difficulties with nova after the pie update? if so what exactly is the issue?I recently had the pie 9 update on phone which by the way I could hardly work it for a month. I'm that person that loves changing the back and the key Board
But oviously not good download this down....not good...I know something or someone is on my phone now but it looks like there protect it..Amways 1st time need navigation and def the best themes having nova launcher
tbh i feel better about this feature. if i left my phone lying around someone could find it and factory reset it and then use it as their own with their own acct. if you reset your phone, it is your responsibility to know your own acct info. even if it was bought used, as long as it was factory reset and then you sign in with your own acct, it is still your responsibility to know you acct info. its not google's fault if you forgot and can't log in. for me this is a very welcome security.It's not for google to conjure up thoughts of stolen phones If a phone's been reset it's none of their business Google has service features for owners to reset their phones if lost or stolen and in that way can determine if a request came from the phone's owner If no such request was made there's no reason to assume the device to be stolen except that someone who bought a used phone is going to be very frustrated and without the use of the phone until they bypass frp Also, people trade in broken phones at cell phone retail stores bearing the names of the big four and selling their plans who then sell the broken phones and they end up on ebay
