New to programing
Hello there all, before you spam me remember we were all beginners at one time or another. Ok with that said I am NEW to programming all together, but I want to learn and I have some ideas that I can not find an app for so I want to do for myself.
Now I have NO programming background, a little HTML and in that I mean LITTLE. So I have read that in todays world it is fairly easy to learn to do this, so I decided to go to the source and start with the forum that came up when I typed Learn Android Programming forums, and well here I am.
So please be honest with me, I am 52 years old so my mind is not as sharp as a 25-year-old, so might take me a while but I am willing to take the time as I am retired and just sit around watching YouTube all day anyways.
Thanks in advance for your help.
Abdulah
I would probably run Netbeans, and don't bother getting into JavaFx, just learn the basics of java, like conditional statements, variables, loops, classes, objects, static/non-static methods, arrays, Strings, Collections.
Start with finding prime numbers or things like that.
Blu Grand M2 home screen search box
Yes, I have tried to long press and drag to remove. After much searching, I found out that it is a "Google Go" search and it cannot be uninstalled.
I just looked up Google Go in the Play Store. When I view it in a browser, it says it's incompatible with all my devices. Odd. So I looked at it in the Play Store app--where it says it's not available in my country. Ah-ha!
It says a similar app is already installed: Google. Okay, so wherever you are, the Google Go app replaces the Google app--but you can't uninstall it. You can, however, disable it. At least you should be able to. Try that and see if the search box goes away.
M20 and M30 specs
Looking over a side=by-side comparison of the hardware specs
https://www.gsmarena.com/compare.php3?idPhone1=9506&idPhone2=9505
There are a lot of very similar aspects between both models, although the M30 does have a big bump in both RAM and internal storage (with similar CPU and GPU, the RAM will be a significant plus for the M30 as far as general, daily usage). Both have similar main cameras, with a significant bump in the M30's front, selfie cam. With both models having such similar main cameras, and this is all speculation, it's also likely both models being released within a month of each other will also have the same Camera app, With such similar camera hardware and software it wouldn't be likely one phone is taking taking significantly better photos than the other.
Folders
Trying to create folder for associated apps on the home page. That is not a system folder.
Your tablet's Home screen is not a folder, it's a graphical representation of a 'desktop'. If you want to nest different app icons into one icon, try drag-and-dropping one icon on top of another. That should result in a single icon that shows tiny versions of those icons inside it.
Otherwise, when you're using a file manager app, or using the Settings >> Storage menu, to make new folders or other such file/folder management tasks keep in mind there are restrictions put in place as to where you have full access to. A lot of those restrictions are intended to keep users from messing up/bricking their devices,
Help How to stop PDF from downloading
Yes, I should have known better! I had just swiped down from the top to see what notifications I had; they're mostly emails or updates, but this wasn't either of those. It had a triangle symbol next to it. For some stupid reason, I didn't think anything malicious could be spread via a PDF, but probably some hacker is clever enough to do that.
TOTALLY DOABLE via PDF, ISIS was certainly using/propagating that method to compromise, hack, and actually find some of their victims.. Also, many ppl and Carriers were pwnd via the Samsung extensions in some websites.Plz be careful in future.
Root "Read-Only File System" when trying to ADB Push an App
https://github.com/kolibreath/MI-fast-boot
adb kill-server
adb root
adb devices
Android hosts (/system/etc/hosts)
127.0.0.1 localhost
adb pull /system/etc/hosts Y:\src\hosts
PC Edit (Y:\src\hosts)
127.0.0.1 localhost
::1 ip6-localhost
89.252.186.72 umutdemir.com.tr
89.252.186.72 https://umutdemir.com.tr
89.252.186.72 http://umutdemir.com.tr
144.122.145.153 https://metu.edu.tr
adb push Y:\src\hosts /system/etc/
EROOR:
adb push Y:\hosts /system/etc/
failed to copy 'Y:\hosts' to '/system/etc//hosts': Read-only file system
23 KB/s (408 bytes in 0.017s)
Help Need help with unlocking bootloader (LG L70 D320n)
Ok I guess I finally found some aboot files here : https://m.mediafire.com/folder/1or45xhf4uttm
There are lots of em for any kind of lg l70 so if anyone reading this wants to do the same just download one of them.
thanx for posting this
I guess I will only need to experiment, i might have some aboot.img in somwewhere but i doubt itis the one i need and im scared to delete the laf partition because without backup ill lose everything :/
good luck!!!!!
Hiding apps
@Dannydet 's idea is the easiest.
there are other ways. you can download a launcher from the play store. a launcher is like a skin that goes ontop of your android phone's operating system. it allows for more customization including hiding apps.
depending on what version of android you have you can just disable the app in your phones settings. but newer versions of android you can't do it.
as you can see the easiest is to just go to gmail on your web browser. you will have to enter your account info each time, but it is much simpler. if you want to try the launcher route and have questions let us know.
Low On Storage
no use google photos. it automatically save it for you. you can even set it to upload only on wifi to save data consumption. google drive works as well, but you have to manually do it. google photos is automatic.
as far as space goes, keep in mind that with internal storage, it is not just one big storage area. it is partitioned into segments. so only part of the 16gb is for your phone's storage. the other part is for your phone's operating system. android os now days are pretty big in size ezpecially nougat on up.
to really not worry about space you need phones with 32 gb on up.
Any music production application (like CUBASE) for Android?
Garage Band doesn't run on android.
Music Memos is an IOS app
Poweramp is a music player not a music production app.
You really want to check that list... :(
And check what the original poster was asking for... they are wanting some serious music production software so something like songify wouldn't help them either
checkout the updated list.
ONN 8" Android Tablet Headphone jack not working.
Update: 10 inch ONN tablet headphone inlet (jack) will work with a system update. I assume it's a driver issue? The update wasn't there couple of days ago so give it some time for the update to register to your tablet. Yes the 10 inch ONN tablet has the same headphone inlet issue the 8 inch has.
Another update: This cheap device definitely has it's drawbacks. You may notice the audio weak with headphones so you may have to install an audio boaster. That'll fix it. At $69 dollars before tax this tablet isn't worth it. It is a $50,00 dollar device. I base that on what I've seen in China at $50.00 with similar specs. My mother can't differentiate between tablets. I did buy her a laptop running a Intel i5 not sure why she felt she needed it. Oh well, she's using it for Facebook etc...
Group Text Messaging App with Individual Replies?
Pretty much all SMS apps give you the option of sending such messages as group MMS (everyone gets all replies) or bulk SMS (everyone gets a separate message, replies go only to the sender). Most people make a choice and leave it there, rather than toggling.
Actually in the UK SMS are effectively free but most contracts charge excessive rates for MMS, so anyone with any sense uses the SMS option, and if they want everyone to see all replies they use WhatsApp or similar instead.
Filter
