Android NOT Samsung
HTC was awesome back in the EVO or Thunderbolt days. Sense 3 was the most appealing UI ever made. Then Blinkfeed happened, flat UI happened, and it was downhill since. I got a bit turned off by the M7 and M8, with crappy '3D cameras' and bland UI design. Blinkfeed was another solution to a problem that never existed. It didn't look like Sense anymore.
I got a sort of Sense 3 clone UI on my Z Flip, with the flip clock widget and skeuomorphic icons, and some older Android 2.x apps replacing some of the 'modern' crap, but I doubt I'll ever be able to recreate that awesome lockscreen weather widget with the animations.
Help Can't recharge phone
I dunno, I just seem to have better luck with the very devices and apps everyone else hates. I love Bixby (prefer it over Assistant as it can do far more), hate USB-C, had no issues with Micro USB at all, and thought the HTC Thunderbolt was the best Android ever made.
I really don't understand. Maybe I would have been perfectly happy with a Chevrolet Vega as well? Lord knows it couldn't have been any worse than my Subaru XT6.
What app is this hearts notification?
Welcome to AF. There are countless notification icons in use these days. Unless someone here is familiar with that particular one, I'm afraid we won't be of much help. I assume you are posting a screen shot from another phone. If this is on your phone, simply pull down the notification shade for additional information. I'm sorry that I'm of so little assistance.
SAMSUNG A53
Brave browser perhaps? Nightly indicates a buggier beta copy. I think that's just an APK you can sideload as it won't be on Play Store.
Is the error something like 'error parsing the package' or 'app not installed?' If so, that's the phone's way of saying it's not compatible.
After Update
IS this a Verizon variant? That sounds a lot like the 'Verizon App Manager' that 'recommends' bloatware apps they think you'll like and you have no way to tell it to frell off.
However, there's a one-time paid app called Buzzkill that can get rid of its persistent notification. Or any persistant notifications you can't swipe away (I hate Android's cluttered status bar and use this app to make it clean)
Search for Buzzkill in the Play Store, and once installed, it is as simple as tapping which app you hate (in this case perhaps Verizon App Manager) and then tapping where it shows clickable text 'do nothing' and then selecting 'dismiss' as the action and then tap save. Then you'll never hear or see it again.
To initially get past the full-screen annoyance, just uncheck each app it selects or tap 'skip' and go about your day.
Help Factory reset Galaxy Tab A7 Lite 8.7 help!
I have a client's Samsung Galaxy Tab A7 Lite 8.7, Model SM-T220 that I had to do a factory reset on because they do not remember the password and cannot do a reset because they do not have access to the recovery email or phone. After the reset, it still requires an unlock pattern on login to the account to finish the reset. Is there any way around this?
Thank you for any help you can provide.
Hi Tamm, the only right way possible is to enter the correct Gmail ID and Password of the synced Google account.
Root How to make fastboot files(img) from the recovery files((zip)?
It's a bit of an old thread (last post more than a decade ago). Things have moved on since then, and these days the simple way of doing what the OP wanted (restore a recovery backup) would be to copy it to a USB drive and connect that to the phone. Thanks to USB-OTG your custom recovery can install a nandroid backup from USB storage, so no need to worry about trying to flash images using fastboot unless you actually want to revert to stock.
SD Cards, and other Disks/Storage Devices
I've not used microSD in my devices for a few years now. Had one 32GB Sandisk that I used with my original 2010 HTC Desire that's still working in my old tablet which I gave to my daughter a while back. Had another 32GB Samsung that failed irreparably (master boot record) after 3 months.
I've occasionally used USB flash drives with Android phones, either to transfer files or as external storage for nandroid backups, that's always worked fine. Never used anything that would need an external power supply with one.
Dart board decision (really, about a dart board)
I was just talking to my da about getting a new dart board, he told me to soak it in water, I said to him what the hell are you smoking!!:eek: Has anybody heard of this before, if so please tell me what hell he is on about. He said it will last longer and i could just not agree.
You NEVER soak a dart board. I've played steel tipped darts for 30 years.
bluetooth headphones not working on specific device
Well at some point there are no viable software-related fixes to try. It's not a common occurrence but hardware failure issues do happen so in this matter if the Bluetooth radio chip has failed, there is no software solution, it's hardware. Since you're only providing details and things you've already tried on a limited basis I'm out of ideas (or at least time to post what are just multiple, repetitive suggestions).
Typically with a hardware related failure, that involves a full to partial tear-down of the phone. And it's not something a novice should try as an experiment. I'm not familiar with a Nokia G21 and since it's very manufacturer and model specific, this could be a big issue if you're your paying out-of-pocket. If you're lucky, the Bluetooth chip is on an easier to replace, separate daughter-board or something like a network related, accessible module (WiFi, cellular, and Bluetooth radios in their own board). Otherwise it might involve a complete replacement of the entire logic board. But this is if the matter is actually hardware related, with remains to be determined. Hopefully others will suggest a fix that does work. But if you don't have the time to drop off your phone to have it looked into, your options are to keep trying to solve this matter using software-related solutions, or accept the fact that Bluetooth audio isn't fully functional on this particular phone.
Website
Which web browser are you using? Safari? Firefox? Chrome or similarly Chromium-based (i.e. Opera, Edge, Brave, etc.)?
Try disabling HTTPS-only mode (well if Safari, apparently there is no user option to enable or disable HTTPS-only mode, by default is should switch itself accordingly):
Help Making a shortcut to playing a specific audio/video file
My android phone will open the camera app if I double press the power button quickly twice. I want to remove this shortcut and also, instead, I want to make it such that, if I long-press the power button, then a file (usually audio or video file, but can be anything) that I chose last time will automatically play. If it's an audio or video file, then it should automatically start playing. Is this possible without making a new file? Is there an app that makes it possible to create this already?
here is what @Dannydet was talking about:
Evaluating Galaxy S3 without battery +
re:SMS
I still use it as it does exactly what I ask it to do. It basically becomes AIM for mobile. two-way chat. All I need it to do, no data needed (and since I hike a lot and work where I only get bars and no data not needing it works better plus no forced app updates like you get with WhatsApp, plus no giving your info to Zuck)
Overseas folks laugh at the US using SMS but it does the job I ask of it. If it ain't broke..
But in the olden days of 1998 when it became standard, they charged BY THE LETTER (especially Cingular, it was 1 cent per letter) so I think that was the origin of 'text speak' with hard-to-decipher messages such as 'whr r u?'
Launching the MediaPlayer
I have tried about 30 or more code snippets to launch the media player and play a mp3 file selected by the content uri. None have worked. They keep getting me tangled up in permissions or other errors. Some don’t even error, just nothing happens. Does anyone have some code to do this that actually works? I would really appreciate some help on this.
Thanks
PS I have the permissions to open the filepicker and select a file, then save its data including the stringUri to a database. I then retrieve the stringUri and convert it back to a contentUri, but I can’t get it to play.
A Fragment that overlaps a control (e.g. button) on the underlying Activity
I have a Fragment that overlaps (entirely) a button control that resides on the underlying Activity in which the Fragment resides.
I know, that's weird, but that's how I want it to be.
The Fragment is initially Invisible when the app starts up. When a certain button is clicked on the underlying Activity that Fragment is made to be visible, using the show() function of the fragmentManager, e.g. :
fragmentManager.beginTransaction().show(theFragment).commit
That works just fine and theFragment does indeed become visible, totally obscuring another of the buttons on the underlying Activity.
So far that's exactly what I want it to do. [ Again, I know that's weird ]
I EXPECT that the underlying, now obscured, button will then be inaccessible to the user. He can't see it, the Fragment covers it up.
HOWEVER, if I actually do a click motion on the place where the button actually resides (hidden, underneath the Fragment), the button actually does get clicked, it's OnClickListener function does indeed get called.
That is NOT what I expected to happen. I figured that if a Fragment obscures some underlying control then that Fragment's UI takes precedence over anything that's beneath it.
Is there a way to indicate that the Fragment does indeed prohibit any underlying controls from being accessed since, after all, the user can't see them?
Yes, I could explicitly disable any and all underlying controls and re-enable them when the overlaying Fragment is again made invisible (hidden). But I'd really like it if there were a way to simply tell the Fragment to take precedence over any underlying controls.
Filter
