First advanced app
Hello everyone!
I am trying to start make my first app. I am not the best programmer, I am not asking you about "how to programming" but for diagram where to start.
My application seems to be quite easy, (but not too easy like WebView option) .
I can pay for any person who want to help me. I need to information what I need to do, Like Step By Step.
Thanks
no such table SQLITE
Hi, I'm a noob in programming android apps. When using SQLite Database I got following problem:
Logcat tells me: "no such table: table1", when I run both methods. Where is my mistake?
I use an existing database, placed in assets/databases folder.
MainActivity
Java:
package com.dplusk.example_sql;
import androidx.appcompat.app.AppCompatActivity;
import android.os.Bundle;
import android.view.View;
import android.widget.Toast;
public class MainActivity extends AppCompatActivity {
    DataBaseHelper dataBaseHelper;
    @Override
        setContentView(R.layout.activity_main);
    public void onClickSearch(View view) {
        dataBaseHelper = new DataBaseHelper(MainActivity.this);
        try {
            String post = dataBaseHelper.getPost("table1","Moser");
            Toast.makeText(this,String.format("%s",post),Toast.LENGTH_SHORT).show();
        }catch (Exception e){
            Toast.makeText(this,"Error",Toast.LENGTH_SHORT).show();
    public void onClickUpdate(View view) {
        //Toast.makeText(MainActivity.this,"Saving successful",Toast.LENGTH_LONG).show();
    public void onClickRows(View view) {
        try {
            long count = dataBaseHelper.numberOfRows("table1");
            String message = String.format("%s",count);
            Toast.makeText(MainActivity.this,message,Toast.LENGTH_LONG).show();
DataBaseHelper
Java:
import android.content.Context;
import android.database.Cursor;
import android.database.sqlite.SQLiteDatabase;
import android.database.sqlite.SQLiteOpenHelper;
import androidx.annotation.Nullable;
public class DataBaseHelper extends SQLiteOpenHelper {
    public DataBaseHelper(@Nullable Context context) {
        super(context, "database.db", null, 1);
    @Override
    public void onCreate(SQLiteDatabase db) {
    @Override
    public void onUpgrade(SQLiteDatabase db, int oldVersion, int newVersion) {
    public String getPost(String table, String nameIn){
        String queryString = "SELECT post FROM "+ table +" WHERE name = "+nameIn;
        SQLiteDatabase db = this.getReadableDatabase();
        Cursor cursor = db.rawQuery(queryString,null);
        StringBuffer buffer = new StringBuffer();
        while(cursor.moveToNext()){
            String post = cursor.getString(0);
            buffer.append(""+post);
        cursor.close();
        db.close();
        return buffer.toString();
    public long numberOfRows(String table){
        String queryString = "SELECT * FROM " + table;
        long count = cursor.getCount();
        cursor.close();
        db.close();
        return count;
Please help me.
GrapheneOS
Hi
I dont know if anyone can help me, I bought a google pixel3a to install grapheneOS, I followed youtube videos particularly Techlore and also used grapheneOS site.
The problem I have is aftler locking the bootloader the phone reads
Cant find valid operating system. The device will not start. Im a bit tech savy with some things but im struggling with this.
Ive searched a lot of forums including this one and other particularly reddit and xda. Ive even tried installing fastboot with adb but it doesent seem to recgonise the phone now. Has anyone had similar issues? I also know this is a fault that can happen with some google phones, if anyone can help please let me know.
Some links ive used to help me...
https://www.reddit.com/r/GrapheneOS/comments/d7h3og/3xl_cannot_find_operating_system/
https://forum.xda-developers.com/t/...sb-driver-installer-tool-for-windows.3999445/
https://www.reddit.com/r/GrapheneOS/comments/e07t56/building_grapheneos_boot_issues_with_locked/
https://www.reddit.com/r/GrapheneOS/comments/celjj7/locking_the_bootloader_after_flashing_pixel_3a/
https://www.reddit.com/r/GrapheneOS/comments/g1j5gs/graphene_install_on_pixel_3a_using_windows_10/
Thanks in advance.
Hey you've probably figured it out by now but don't use any installation guide other than the one included on the GrapheneOS site. Also they have a nifty USB based installer that you use on their webpage. Unless you're tech proficient don't try and do the manual CLI installation
About rooting Galaxy core prime g360h without pc
Im guessing @sepide has installed the TWRP app as opposed to flashing a custom recovery as that would require a pc. The first time I rooted (Galaxy S3) was with an app. It gave me some experience in regards to android root and at firsy I was extremely great full to finally have root access. That lasted about a day lol. For the next three or four weeks I was battling that dam app for control. It was a mimic of SuperSu without the app controls. Furthermore it didn't even have an icon, just a pop up allow, grant, promp and no app interface. It foced me to learn the file systems (so what ) and replace it with SuperSu. Even so I had no idea what possible malware was left in the file system. A few months later, I used a pc program to flash
Cyanogen Recovery (yes that long ago lol). I now use TWRP custom recovery and have no use for the app itself.
ahhhhh yes you are right twrp does require a pc.....i think the op is SOL then without a pc.
op can't you borrow or use a friend's pc to fully root your phone?
Help lost phone with (UK) sim card, in Thailand, new phone won't let me sign into google account
Hey, you can talk to the carrier company when you'll reach your country and get the same number again in order to access all your accounts and other stuff related to that number. It's the best way possible to retrieve your accounts.
I also faced this issue and Google won't let you in unless you're signing in from a familiar phone that you've used in the past to log in or Google had already recognized as the trusted device.
Camera won't save photos to SD card anymore
I have a LG Stylo 6 one minute was taking pictures and they were going to gallery and the next thing every time I took a picture as soon as it clicked it said picture can't be saved. Checked Sd storage have room everything else seemed fine so went to text tried to take a picture when adding image same thing pic can't be saved. When those things look normal and won't save restart your phone as soon as it restarted took a picture and back to normal.
Samsung Galaxy S8 phone wore out?
https://www.satellite-reviews.net/dish-network/dishnet-internet
So if you have dishnet, as you are stating, for cable TV, you already have internet also. You should have a wifi connection at your home, turn wifi on your cell phone and connect. No cell data needed.
I read the article and I got rid of satellite internet in 2013 when I discovered mobile wifi and tethering because I was always having problems, not getting the speeds they were projecting, plus the individual cost and that was a separate bill from Dish network. The speed is incredibly important for work downloads. I plan to call AT&T again because I didn't start having the recent problems until a few months ago. According to their wireless maps, I'm now assigned to a totally different tower than I was over a year ago. I think that's the problem!
Help Location turned itself on randomly while watching youtube and the notification deleted itself
Those are settings within Settings > Location, but they aren't separate apps on my phone (Pixel 2, Android 11). I expect that both of those are "on" by default, though I turn "Location Accuracy" off myself.
But there will be system apps that have location permission by definition. For example, you can't deny location permission to Google Play Services, you can only turn location off completely (Google's location service is part of Play Services, so if you have any app that uses Google's location service then Play Services has to have location access).
"Google Location Accuracy" is misnamed anyway: it's the setting that turns on wireless network location, not something that improves accuracy (at least not if you have a GPS fix - if you haven't then even the crude location you get from networks is more accurate than nothing, but if you have a GPS fix their contribution to accuracy is negligible). But it is a setting that is very easy to turn on without knowing it: any app using a particular Google API is likely to feed you a pop-up when you use it that tells you "For a better experience, turn on device location, which uses Google's location service". That's designed to sound like you have location off, but it really means "enable this setting" (if you have location on but that setting off it means you only use GPS for location). I particularly hate the dishonesty of this pop-up because if you go to Settings to turn this on there is a disclaimer that tells you that enabling it allows Google to track your location, but if you touch "OK" on the pop-up, which is already deceptively named, it just turns it on without showing the disclaimer.
Filter
