changing AOD image
- By kokiangel
- Smartphones
- 3 Replies
I downloaded AOD-Walls from the google play store and can add my own full screen images to my AOD now.
public void querySkuDetailsAsync(@BillingClient.SkuType final String itemType, final List<String> skuList){
// Query the purchase async
SkuDetailsParams.Builder params = SkuDetailsParams.newBuilder();
params.setSkusList(skuList).setType(itemType);
mBillingClient.querySkuDetailsAsync(params.build(),
new SkuDetailsResponseListener() {
@Override
public void onSkuDetailsResponse(BillingResult response, List<SkuDetails> skuDetailsList) {
for (SkuDetails skuDetails : skuDetailsList) {
String Sku, Title, Description, Price;
Sku = skuDetails.getSku();
Title = skuDetails.getTitle();
Description = skuDetails.getDescription();
Price = skuDetails.getPrice();
MyIAPProduct.setSkuDetails(productsDetailsARR, getApplicationContext(), Sku, Title, Description, Price);
public static void setSkuDetails(ArrayList<MyIAPProduct> arr, Context cnt,
String Sku, String Title, String Description, String Price)
for(MyIAPProduct prod: arr){
if(Sku.equals(prod.m_Sku)) {
prod.setSkuDetails(cnt, Title, Description, Price);
public void setSkuDetails(Context cnt, String Title, String Description, String Price)
m_Title = Title;
m_Description = Description;
m_Price = Price;
saveToPreferences(cnt);
public void saveToPreferences(Context cnt){
SharedPreferences sharedPref = ((Activity) cnt).getPreferences(Context.MODE_PRIVATE);
SharedPreferences.Editor editor = sharedPref.edit();
editor.putBoolean(m_Sku + "Purchased", m_Purchased);
editor.putString(m_Sku + "Title", m_Title);
editor.putString(m_Sku + "Description", m_Description);
editor.putString(m_Sku + "Price", m_Price);
editor.commit();
void handlePurchases(List<Purchase> purchases) {
String str;
int numberOfPurchases = 0;
for(Purchase purchase:purchases) {
switch(purchase.getPurchaseState()) {
case Purchase.PurchaseState.PURCHASED:
if (!verifyValidSignature(purchase.getOriginalJson(), purchase.getSignature())) {
// Invalid purchase
// show error to user
Toast.makeText(getApplicationContext(), "Error : Invalid Purchase", Toast.LENGTH_SHORT).show();
return;
// else purchase is valid
//if item is purchased and not acknowledged
if (!purchase.isAcknowledged()) {
AcknowledgePurchaseParams acknowledgePurchaseParams =
AcknowledgePurchaseParams.newBuilder()
.setPurchaseToken(purchase.getPurchaseToken())
.build();
mBillingClient.acknowledgePurchase(acknowledgePurchaseParams, ackPurchase);
//else item is purchased and also acknowledged
else {
numberOfPurchases++;
// HOW DOES IT KNOW IF IT IS CONSUMED???
// DONT DELETE - if you want to keep on consuming
// ConsumeParams consumeParams = ConsumeParams.newBuilder()
// .setPurchaseToken(purchase.getPurchaseToken())
// .build();
//ConsumeResponseListener consumeResponseListener = new ConsumeResponseListener() {
// @Override
// public void onConsumeResponse(BillingResult billingResult, String purchaseToken) {
// Toast.makeText(DiamondsActivity.this, "Purchase successful", Toast.LENGTH_SHORT).show();
// if (billingResult.getResponseCode() == BillingClient.BillingResponseCode.OK) {
// if (purchase.getSku().equalsIgnoreCase(ITEM_SKU_diamond_500)) {
// Toast.makeText(DiamondsActivity.this, "Thank you for purchasing!", Toast.LENGTH_SHORT).show();
//billingClient.consumeAsync(consumeParams, consumeResponseListener);
break;
case Purchase.PurchaseState.PENDING:
Toast.makeText(getApplicationContext(), "Purchase is Pending. Please complete Transaction", Toast.LENGTH_SHORT).show();
break;
case Purchase.PurchaseState.UNSPECIFIED_STATE:
Toast.makeText(getApplicationContext(), "Purchase Status Unknown", Toast.LENGTH_SHORT).show();
break;
@kendallkanderson I'm afraid we're not going to be able to offer you much help here. That appears to be an issue with the app so you'd need to contact the app's developer to get it sorted out.
I'd normally advise you to use the app's listing in the Play Store to find the developer's contact details but (surprise!) it doesn't look like that app is available on the Play Store. I agree with @mikedt here; it sounds like a scam to me.
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical" android:layout_width="match_parent"
android:layout_height="match_parent">
<TextView
android:id="@+id/textView"
android:layout_height="wrap_content"
android:gravity="center_horizontal"
android:text="Menu"
android:textSize="50sp" />
<EditText
android:id="@+id/editTextTextMultiLine"
android:ems="10"
android:gravity="start|top"
android:inputType="textMultiLine"
android:text="Select a layout type to view an example. The onClick atribute of each button will call a method which executes setContentView to load the new layout." />
</LinearLayout>
<androidx.constraintlayout.widget.ConstraintLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
xmlns:tools="http://schemas.android.com/tools"
tools:context=".MainActivity">
<TextView
android:layout_width="wrap_content"
android:text="Hello World!"
app:layout_constraintBottom_toBottomOf="parent"
app:layout_constraintLeft_toLeftOf="parent"
app:layout_constraintRight_toRightOf="parent"
app:layout_constraintTop_toTopOf="parent" />
</androidx.constraintlayout.widget.ConstraintLayout>
Yeah if you could find a home landlines or a payphone. Do not try that at work. Just lately my security company installed landlines that record every conversation.@dontpanicbobby I used to do a 1KHz whistle to start the handshake with modems and faxes. I probably still could.
