Does anyone know where to put ring tones in 2.2?
In 2.1 all you had to do was put them in a folder called (wait for it) Ringtones but that doesn't seem to work in 2.2?
Thanks
), but couldn't you download a ringtone and then search for where it got installed? I'm a default ringtone kind of guy so I don't really know much about them...but this might work. Just a thought!
Thanks
Piiman,
Don't have 2.2 (or root--yet...), but couldn't you download a ringtone and then search for where it got installed? I'm a default ringtone kind of guy so I don't really know much about them...but this might work. Just a thought!
Cheers!
And those are the ones that don't work any longerThanks for noticing. I'm pretty sure Droider13's a bot thoughP.S., you and droider13 and doing a great job helping folks out in the Droid X root forum! Looking forward to rooting my DX when the time comes...![]()
he's always in the thread in like 3 seconds flat
No human can move between forum threads that fast! yea just browse to it with astro. do a long press and select set as. pick ringtone and it'll now show up in your ringtone list for alarms and what not as well.
Just use RingDroid in the app market. Then select the file through it, save as "notification or ringtone" and it will be in the correct folder when you try to change your ringtone/notifications.
After installing ringdroid they all started working again. But I can't find where ringdroid saved the ring tone I made Lol oh well my old ones are fine again.
thanks all
Thanks for noticing. I'm pretty sure Droider13's a bot thoughhe's always in the thread in like 3 seconds flat
I am not a bot for your information![]()
I use ringdroid to make all my ringtones, but all the ones I put in my ringtone folder work just fine with froyo.
add a folder called "ringtones" in /media/ then add files using cut and paste or mass storage, etc.
-QD
Samsung Infuse. 2.2
I always move my ringtones into the system/media/audio/ringtones folder and change the permissions. That way when my phone is plugged into a computer it will still use my ringtone if I get a call.
Holy dig-up-an-old-post Batman!!!
I always move my ringtones into the system/media/audio/ringtones folder and change the permissions. That way when my phone is plugged into a computer it will still use my ringtone if I get a call.. Holy dig-up-an-old-post Batman!!!
If it's worth doing, it's worth overdoing! (Robert A Heinlein, I think.)
).and just did that.... with root explorer, and my mp3 files did not show up when i tried to select them. any ideas ?
