Root 4.3 BeanStalk
nice!!!!! gonna download this now.....and so far i have had 0 issues with gps on aosp. but they come from lotk and jamie's roms, but i will let you know EM if i have any issues with it tomorrow.
What's up with the navigation bar options? We have capacitive buttons. :confused:
Anything like DSP Manager on board?
Can I assume that it's stuck with the stock camera app?
Edit - ok, the description for the rom is copied from the original for the Infuse, using soft buttons.
And the Infuse version claims working GPS a few revisions back.
I discovered a pretty cool app -
Check out "Ultimate Dynamic Navbar Lite"
https://play.google.com/store/apps/details?id=com.mrbimc.udn.lite
Considering adding a navbar to supplement the hard keys.
Edit 2 - from the Ultimate Dynamic Navbar -
Q: Android 4.3, can't hide notification. Is it possible to fix?
A: No, since google fixed bug I used to hide notification. There's no way to hide notification anymore :(
It's always something, but maybe it'll work here.
Edit 3 - I wonder if I can get the MeanBean camera working with this - or maybe the MeanRom one, that one moved around easily in ICS.
Downloading now. Between backups and reconfiguring it usually takes me quite a while to learn anything.
I'm going to miss the camera, the gallery/photo editing and probably the mail from Sense.
The camera and gallery/photo editing could be deal breakers for me.
Fingers crossed. :p
sorry EM just woke and have not played around with it too much. there are some cool tweak apps cooked in. there is definitely a lot of stuff going on that i need to play with for the next few days......gonna see how battery life is on the stock kernel. i wonder if the komodo kernel will work on this or not. i need to read the thread i guess.....LOL
Had to go to settings, system, hardware keys (all the way at the bottom) to get to the hardware button mapping.
Had to turn on the nav bar so I could use app menus until I figured that out.
Also - under /mnt/sdcard/ext_sd, I seem to have two orphan files at the mount point. Anything is possible with me, others may not see that.
The sd card is under /external_sd - could not get any app/data restore working until I figured that out.
Edit - well - a full app restore was a mistake. :rofl: I'm picking up things from my old setup that I ought not have bothered with. :rofl:
Ok - DSP Manager works. DSP Manager is baked in.
I flashed gapps - it said it worked. I was surprised that I had to flash YouTube and Maps separately.
GPS lock (3G, no wifi help) was very fast, reasonably accurate, I was at 10' after using GPS Status to calibrate the compass and pitch and roll.
Stock camera app is brain dead. Useless to me. Need to decide if going to mess with something else or go for Camera JB+ here.
Didn't expect it to work and FM radio didn't.
It's ok.
Probably a boon to AOSP lovers. I'll drive it for a day or two, see if that grows on me.
So far nothing is actually failing.
Camera could still be a deal-killer for me - MikeXDA still has the best I've used.
Aside from dialing myself, is there a voicemail on this?
I really like the performance here and the support features.
This is really a pretty well polished work in my opinion.
If I were going with an AOSP rom, it would be this one.
I had a few of my favorite apps just not act the way I wanted on HTC JellyBean but did exceptionally well here.
The animations are really fluid, top notch.
But I prefer speed so I turned them off and liked it even more.
I also found that it responded very well to my shmmax mod in my experiment thread - set it to 384 MB and it *really* flew.
I recommend this rom strongly to any AOSP lover.
I'm sure you will all have your own preferences but I think it is definitely worth a full test run before deciding.
In the end, I'm addicted to MikeXDA's camera and Viper ICS (no longer supported) for my needs.
But I will be trying this again with Camera JB+ as a compromise on the camera.
I couldn't hate the one that came with it any worse but that's not the rom's fault.
Per usual, I ran this with the Nova launcher but maybe the others are even better.
I'm sure I'd have more opinions, plus and maybe minus, if I gave it more time.
The deal here is simple. The original dev made this for the Samsung Infuse 4G.
Here's the thread with the changelog -
http://forum.xda-developers.com/showthread.php?t=2091900
He's a righteous dude and put everything out there to cross build to other phones, that's what this effort is. And the guy that put this together seems pretty righteous as well. Edit - he's just building it, says his phone doesn't get along with JellyBean.
So - I think that the changelog tells another positive story and hope this version gets maintained.
There's my two cents, your mileage may vary.
I think we need this thread in our rom sticky, hint to anyone free for that before I am. :o
PS - with my typical apps and services loaded, I was using over 600 MB of ram, about 630 I think, out of about 780 (going by memory) right after startup.
I'm used to hearing about CM and AOSP being lean on memory. I'm used to saying that if you run a lot of features and apps expect to use ram. I did and saw no performance issues.
Not sure if that's worth mentioning but that's my opinion.
yeah this thing is pretty fast right out of the box. the android tweaker app is pretty cool, so cool i bought the pro version. i used the auto tweaker and set it to performance. if you feel like it you can tweak it yourself....but i'm lazy....LOL
i'm 12 hours in and i'm at 69%..... i have not tried gps just yet, but it found my location pretty easily enough. will try that out tomorrow.
it has halo(which i have never used before) and pie.
like em says it does have dsp manager....i will see how the sound is tomorrow.
i like it so far......still lots of stuff to play and learn from this rom, but i agree this is finally a rom to give pacman a run for its money.
I thought that the sound was fuller, clearer I guess (less noise) with this compared to DSP Manager added to Viper ICS, but the equalization changes were less dramatic. I'm a fan of DSP Manager so I played with it a bit.
PS - if you change your mind, see what happens with the tweak I suggested.
well granite not sure if you will have the same issue as me, but sms would not work right on my phone. i nandroid back to pacman and my sms works now.....i will be reflashing beanstalk in a bit, but i need sms at the moment.
Is your prl and profile up to date?
Straws. Grasping.
yep.....LOL it works on pacman which i just nandroid back to.
i'm gonna re-download and do a fresh install and see if that fixes the issue. but for now i need my texts so it will have to wait until later on tonight.
Texts work fine for me. I'd re-download and flash fresh Ocn.
This thing is really fast, and lean! Rom is only 200MB.
Liking Nova Launcher so far.
I need to find a good clock app.
Man, my battery was not good over night.
Dropped over 40% in 7 hours while asleep. Phone slept good too, no wakelocks that stand out. Had WiFi on the whole time, maybe it doesn't sleep like it does on Sense?
I really haven't messed with AOSP roms for a while. Watching....Learning...
PS: Thanks for the clock suggestions doods! :D
