My reason for asking is because Im hoping to get his "Back To Stock" theme. I have his black glass theme currently but Im trying to figure out why I cannot update to the new version of android as well as the new version of facebook. Trying to take it one step at a time so that I am able to find out the reason that these installs are failing.
If nobody knows about 928 droid, does anybody happen to have a solution to my problem as a search turned up alot of nothing (so it seemed).
If you just want to deodex you can get a deodexer .zip that works for .340 at 2.3.340Deodex.zip
Themes For Stock ROM - 2.3.340 - xda-developers also has some themes for stock if you want the theme without a full on ROM.
Yes. I don't see the point of downloading a ROM when I can get the components of it I want manually. So I used those update.zip to deodex and theme, downloaded a gb keyboard apk somewhere else, overclock using jrummys app, and freeze all the bloatware using TiBU. Practically all the benefits of ApeX but everything done the way I chose to.Raryn, Have you used that program. I have it downloaded but since all the ROMs deodex for you I haven't had to use it.
+1 ..i had it installed all of 5 minutes lol ...not taking anything away from the devs obvious hard work but it just wasnt my tasteI don't understand all this love of the 928Droid theme. That was my first theme and I don't recall it as being exceptional.
