Alright sounds good, I think Im gonna go for it and see what happens, I have nothing to lose since I did the nandroid backup sucessfully!
icking up thread:: +1 on what evomatt said, people have a tendancy to use rom manager becuse theyre kinda put off by the way the flashing process looks. Ill even admit that it intimidated me, looks like serious business when you see it for the first time LoL with your nandroid b/u, you shouldnt have anything to worry about. That being said, id take a copy of your nandroids and put them on your computer as a backup in case of (albeit rare) micro sd card failure. Also keep in mind that when going from roms like Konis stuff(sense based) to roms like CM7 (aosp android open source project) you need to wipe far more thuroughly. Caulkins format all usually does the trick just fine. And sms backup/restore has been of great use to me as of late(i hate losing all my mssgs lol)OK so I am a little late to the party but wanted to chime in with an excellentvend all confusion for the future
Its called quickboot and is in the market. It gives you the reboot options of recovery bootloader etc without fiddling with the pesky power or volume buttons
LOL and maybe that would pacify some people but i would not be content with hey just use an app. I would have still beat that dead horse into submission lol![]()
that dead horse had it comin anyways lol
your sig doesnt actually link to koni...?
i need to fix that, but i think im goin back to CM7 anywho, so it might end up being a moot point lol
Im an idiot I didnt hold them long enough, I was holding for 2-3 seconds not 4-5+ Im in bootloader now onto my OP. Sorry about this guys!
Titanium Backup wont open/show its installed
Steps needed to get Konis ESIII on my phone- Complete Noob
Steps to make my Battery LAST
How to use SetCpu or a good setting to have it on so my battery lasts
Thanks a lot and yeah sorry I held it for 3 seconds expecting it to work because I remember when I did a temp root last time i held it for 1-2 seconds and it worked fine but yeah I am still having battery issues. I am looking for a ROM or maybe a kernel(Dont know much about these) that will help make my battery last 8+ hours. I have a few setcpu profiles to help make my battery last, like i have the cpu underclocked when my screen is off but to no avail it died in 5 1/2 hours yesterday, i had brightness at its minimum but i was using the wireless tethering for my ipad and friends and i did have 4g checked off, is there any extremely user friendly, task manager that I can rely on, maybe one just for rooted users. I guess in conclusion Im looking for a ROM/kernel that can help my battery last what other roms do you guys reccomend since I dont know much or anything about kernels.
EDIT: Also for the Wireless tethering app, when using a speedtest I only get 1mbs and about .3-.5 mbs upload. Although the odd thing is on the app itself it says 9mbs and for a while was locked at 29mbs and up, yet i was still getting really low mbs on my speed test, not sure whats going on.
Ok I think Ill check on the rooting for dummies guide to find how/what to do with kernels haha and yeah I have the screen off at 245,245 and I have the perflock disabled so Im under the impression when its at 245,245 its in the process of being underclocked to saved battery. For the temp> what should I set it to?
Alright cool, what temp should I put under the SetCpu profile for Temp>
After doing some research, I am going to try installing the Heyitslou #8 kernel to help enhance my battery life. So basically I put it on my sdcard and do the same steps as I did with the rom, and then it will reboot with my same rom just a different kernel?
EDIT: Nevermind that kernel is for the incredible where can I find KINGS #9 kernel I did a search on the forums but no luck!
