KA24DERACER
Hello all. I would like to offer my insights to the random rebooting problem that some people have been having on BrokenOut ROM.
Now when I first installed BrokenOut I had the "factory" No Frills CPU, the LG Connect Optimizer and I had just bought RomToolbox Pro as it had a LOT of features I liked in one very well programmed app. And at first I did have a couple of random reboots (about three or four with one of them being my fault). After thinking about it for a while I noticed that MANY of the functions of these three apps and a couple more were the same. So I uninstalled all of the conflicting apps leaving just RomToolbox. After I did that I had no more random reboots.
If you are having troubles with random reboots I would suggest trying to find ALL of the apps that have similar or identical functions and try and consolidating them. Not only will you save RAM and running processes, but Im pretty sure it will DRASTICALLY improve your stability. I would appreciate anyone who tries this and has it work for them to post so I can see if my theory is correct. Hope this helps someone.
otherwise the clock speeds will still revert.
You have evidence?
So I restored the file from the ROM's flashable zip. I recommend editing it than deleting it as for, as the name of the file suggests, it applies settings upon booting. There most be another file somewhere putting the clockspeed up to 1.5GHz, but editing the file ultimately corrects this.
