bigbear6708
used the capt throwback method...do I need to keep the flash_img and mtd-eng.img files on my sd card? just want to try and clean some stuff up.
also...could someone help me out with battery life..
I am still on stock battery, and with mikg3.0, antrhax, and ultimaterom tweaks...my battery does not seem to be lasting too long with low/moderate use.
I basically text, a few calls, light internet browsing. I toggle mobile data and use wifi whenever possible. the only thing i could change is set my screen brightness lower..I currently use auto detect.
I jsut flashed anthrax yesterday..so i understand to give it a little while to settle in..what other options may I have though..other than trying a new kernel..and what kind of performance should I be expecting?
pri is 2.33_003
currenly on 8 hrs with this battery.at 15% left...not to good!
edit: setcpu is at 245/998 inter X (figured screen off with this one was lower than smartass..am I wrong?)
am i missing something..would there be something running in the background I should look at stopping??
pri is 2.33_003
