If I already have CloclworkMod
do I have to delete it first before installing
Amon ra?
Thanks.
just flash the zip from clockwork recovery. i think its a pc36img.zip file, so you put it on the root of your sd card and let the recovery do an automatic update
After installation then, does Amon ra become the "default" recovery?
Also, there is an image file on the XDA site by the name of
"recovery-RA-supersonic-v2.3.img". Is that needed?
Also, if I get /sdcard/ and then a bunch of folders, just drag and drop the ZIP file outside of one of those folders and that will be the right place for it to be?
Thanks.
When I rename the .img file, there will be two zip files now instead of one to put on the sd card, correct?
For some reason the post on XDA had links to both the .IMG recovery file and the full ZIP file ( both same size ) and with my new limited knowledge, I thought both were needed. Live and learn.
I just hbooted and the message "no image" popped up when it was running the boot up for new sd card contents.
What is going on with this?
I selected yes to update and it was over in a second.....
Maybe I should try your earlier suggestion to zip up the .img file and update that?
It says "parsing sd zip - recovery ok"
That is the one I just put on the card and tried to update.....
and am prompted "do I want to start update?"
The answer is yes
Volume up
Again, it finished very quickly...
I just rebooted. I don't have terminal emulator installed yet.
try redownloading the file, and replace the file you have on your sd card with the new one and try 'er again
What the heck?
What the heck?
