I have s6 edge, how do u make icons only appear on main page and not twice on both the main page and 'apps' drawer.
Think of it as similar to Windows Start Menu. Even if you have the app on the desktop, you stilk have them in the start menu. Plus the ones on the homescreen are just shortcuts. Not the actual apps themselves.
Windows is more flexible a stand alone application or executable can run from the desktop without ever hitting the start menu.
The point being made was that they're still there whether you open the Start Menu or not, similar to the app drawer in Android.
Unless you run the Windows .exe from a CLI you need to have a shortcut on the Windows desktop. Android's home screen icons are functionally similar.
