Tried to update Bluetooth file transfer app and everything seemed to be going according to plan re the download until near the end when it said "package file was not signed correctly". Anyone any idea what this means and how do I overcome it.![]()
Would like to ask u or anyone else a rather basic question (put it down to my age !!) how do I move/rearrange or remove a widget from the home screen ? Have tried clicking on widget and dragging it to launcher but all it does is move the whole screen. Can see how to add them to the home screen using the menu -add feature but not how to move/remove.
Hi,
Does this product work with HDD? I have a one TB one hard drive and I would like to be able to use this product as a media player 720p or HD doesn't really matter to me as my tv is only 32".
Thanks all.
I have had the same problem with some apps that were pre-installed on my FV1.
I have not tried this yet, but you could try deleting the pre-installed app (make sure you clear cache and data before pressing "uninstall"). Then I believe you will be able to install the new version.
If you can make a backup of the pre-installed app first this might be useful, because there is no way to know if the new version will be compatible with the FV1.
Good luck, and let us all know how it goes.
. I want to gift this box to my parents, who have very limited knowledge about computers. I felt this interface will be very good for them to access the web.
I'm planning to buy one of these boxes with android 2.3 which says it can support skype. I'm not sure if this means it can support video calls ? if i attach a USB microphone & USB Camera?
Im in china at the moment. so got some infinite options to buy from. but no demo watsoever.
Thanks in advance
I have an fv-1, worked great for 3 weeks ,today opened with a post:" the application launcherpro ( process android.process.acore )has stopped unexpectedly , please try again"
there is a square with the option :" force close "
as the -force close -do not work ,tried to turn off and on , but nothing helps.
as I am new to android systems , I am helpless.
if anyone can help me , please answer me
thanks in advance
yours
menachem
)Hi,
The above two boxes have hdmi port. I have ordered the first box which should be with me in a few days. I'll post my feedback as soon as I have a chance to play with it.
For the second box, there is already a post about it in this webboard. It's called r-Box. It definitely play and output native 720p.
It does not help me as the alarm covers my scren and I can not get ride of it, so I can not do any thing.No issues .do not waste time for it. Just backup your applications.Go to settings /privacy/and do factory reset.your box will be fine.Later you can restore the apps. A few weeks back i have done the same for the same issue, Just make sure that power shouldn't be interrupted during the restore.
Thanks
If you can help me in this matter , I will be thankful
yours
menachem
@in_msz
Can be the latest fv-1 (october) firmware be rooted with z4root easily as it is with default firmware? Thanks
I won't have trouble with that, and need to have root to install some apps for accesing windows shares, enabling remote ftp, setting up dlna server, etc.
