Hey, Folks I hope this belong to the "rooting" section, as possible answer to my question requires a rooted phone.
I got very annoying message in my rooted ZTE ZMAX (stock ...b22 ROM t-mobile)
Network with limited service found. Do you want to initiate network search?
I have manual mobile network selection enabled, and I do not want to switch to automatic, as signal is patchy, and phone will often go roaming, and then sit there for a long time (behaviour familiar to Wind Mobile Canada customers, eh?
Can anyone suggest what do I have to edit in the system in order to get rid of that message.
I hope it is some configuration file like build.prop where one can change the value of a variable.
Thanks a lot in advance!
![Smile :) :)](/styles/smilies/google/smilie.png)
