Root *Anymore Modding idea's?* plz post. :)
thegummyjar
Wondering any good idea's for more mod's to do, or App's, or any good add ons. you will be thanked if you reply. :)
Ok DX :
Gummy 2.5
Watermark 2.5
DX Bootstrap
Milestone OC
ADW EX Launcher
Super user
Root explorer
Z4 root
Beesley's Droid X build.prop
NexusKang live background
Ok DX :
Gummy 2.5
Watermark 2.5
DX Bootstrap
Milestone OC
ADW EX Launcher
Super user
Root explorer
Z4 root
we were discussing earlier possibly being able to have an update.zip for gummyjar to add the blur alarm and maybe messaging.
If you take a lot pictures I would check out vignette it's a paid app but well worth it and you will not regret it. I've taken awesome looking pictures for a camera phone. Widget locker is definitely a must for me. I'm not sure how I put up without it for so long. If you get it check this thread out for some sweet mods. I'd also recommend Desktop visualizer. This app lets you replace homescreen icons with any image of any size.
ok if its possible i would love to see a messaging apk that puts gmail gtalk and sms and mms in one app, if you can do that ill pay for it :)
Stock camera. Hey Aggie12, I flashed the camera file you provided on the other thread, but the panorama option doest work...:confused:
I may have misunderstood the post lol......tasker or profiler are good apparently if you like everything on auto set without you having to remember ...like widow or other settings ...tasker is a little confusing but its still good once you get the hang
I would like this. I was thinking it would be very nice to be able to add widgets to the top of the lock pattern screen, or even if you could change the clock or have some system info "such as temp, ram usage, and processor speed". I am aware that you can add widgets to the slide to lock screen.
Since you're rooted get 'AdFree', gets rid of all adds in free apps. Another must is 'AutoKiller', this ramps up your phones natural application kill process and gives you a greater buffer zone (not to worry, this is NOT a task killer). I use 'Hot Reboot' a lot, you can choose either a hot reboot (which starts everything over, without turning your device off), or a regular reboot. 'QuickClock Advanced' is a good app to have it you like to play around with your OC variables. And 'Search2Play' makes your camera button a play/pause button for your music player... if that interests you any.
Dling apps now, I have Auto Killer just haven't messed with it yet. I want to get the cracked nexus kang Apk. it is only a buck in the market but I dont have a bank account. Im a cash only guy.
Gotta have ROM manager so you can apply clear names for each of your nandroid backups if you constantly like to test different ROMs and themes but need a backup to go back to if you change your taste at one point.
this is also easily achieved through most file managers.
I prefer estrongs
