I like Sense roms but every single gingerbread rom I have used lately had issues on my phone. Now I am looking for an AOSP rom that has GPS working and a voicemail application like the one we find in sense roms. Any suggestions? Thanks.
AFTER flashing CM7,did you then flash GAPPS? (google apps).if not,go back into recovery and flash the latest GAPPS.zip and you should be good to go after you sign into your GMAIL.(YOU MIGHT HAVE TO FLASH THE ROM/GAPPS FRESH IF JUST FLASHING GAPPS DOESNT SEEM TO WORK)but it SHOULD fix your problem.I'm also new to rooting and I am trying out CM7. However, I'm not sure how to get apps directly from the Android Market. There's no market app included on the ROM. Am I missing something here?
cm7 + tiamat kernel = epic win
Gingerbreand and CM7 are not harsh on your battery with wifi, or they shouldn't be so long as you maintain the wifi connection. Set your wifi sleep policy to "never sleep" and it should be fine. A wifi connection will actually use less battery than the 3G radio, so wifi is definitely a good thing.AFTER flashing CM7,did you then flash GAPPS? (google apps).if not,go back into recovery and flash the latest GAPPS.zip and you should be good to go after you sign into your GMAIL.(YOU MIGHT HAVE TO FLASH THE ROM/GAPPS FRESH IF JUST FLASHING GAPPS DOESNT SEEM TO WORK)but it SHOULD fix your problem.
ALSO,be aware that GINGERBREAD AND CM7 are harsh on your battery while using WIFI..the TIAMAT kernel helps along with SETCPU profile for when screens off and a battery calibrator.but other than that CM7 is a damn near a perfect 10! MY PERSONAL OPINION,if Cyanogen could SOMEHOW put the sweet sense widgets into their ROM,it would be a PERFECT 10!! ESP,if they theme!!![]()
I'm with you on CM7 and Tiamat. I don't know why my phone likes Tiamat so much, but my battery seems to be way better than with using SavagedZen. I'm running 4.0.2 right now. I can get a solid 24 hours off the charger with no problem. I ran one of the newer versions and I didn't feel like my battery life was quite as good.+1 to cm7! And the tiamat kernel combo. You're very likely to receive many of the same recommendations as its just solid as helleverything works on it nowadays so, make a nandroid and flash away, if you dont like it you can always restore
