Totally cool!
I registered on this forum to comment on this cool app.
First, if nothing ever changes with this app I will continue to use it (until something better comes along)
Now a few observations comments and requests.
I installed this app for the charging LED indicator - this part is great. Personally I do not want the LED on during discharge and this is a bit challenging to manage. In the general settings there is the LED Notifications check box to "Display chaging state via LED indicator". Can you make options for charging only, discharging only, charging and discharging, none? This would allow the user to select charge state colors for the notification icon without having the LED glaring at you. Other options and suggestions for this follow...
Your action/color options could use some re-org and this might also be an alternative fix to the above mentioned issue. LED off is really an action, not a color - guess where this option belongs!
Moving this would make settings more logical and easier to understand and use - at least for me. It would also allow the user to set the color (for the notification icon) without having the LED turned on.
I would also like to see separate settings for charging and discharging in the percent charged settings. I would set discharge to green for most of the discharge changing to amber and red as the charge state gets low. Conversely I would set charge to red until the charge state gets high, then change to amber then green as the charge state goes into 90% and 100% respectively. Just my thoughts on this status indicator...
These not insignificant changes would greatly improve this app in my opinion.
Thanks for the app, and thanks for listening;
J.P.
